removing pinstripes over clear
Old Apr 26, 2009 | 07:59 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I just bought an 85 and its got some stupid pin striping on it,, I want to take it off,, it was painted over the clear coat. Someone said paint thinner would take it off and I asked my friend who is a professional body man and he said thinner would be too strong and it would eat through the clear coat,, he said I should use reducer because its less strong and should take off the stripes. Would using reducer be the best way to take the stripes off?
Old Apr 26, 2009 | 08:18 PM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
Re: removing pinstripes over clear
depends on what kind of paint they used to put them on with. if they used a two part activated paint you might not get them off.
Old Apr 26, 2009 | 08:50 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Try using some polish thats safe for clearcoat paint. I know our detailers rub thru them all the time ... dumba$$es
Old Apr 26, 2009 | 09:46 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
reducer should be fine, then go over it with compund.....glaze and wax and your done. and jus fold a naplin in half and use an ehge of the paper towel....the less you use the better...
Old Apr 27, 2009 | 04:51 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I tried wiping reducer on with a rag, didn't come off.. not sure what your talking about..
Old Apr 27, 2009 | 05:09 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
If they used 'oneshot striping enamel' you're in a tough spot. If I was you, I would find a website online called pinhead lounge. Its a website for panel stripers. (If you have some time to kill...their work is amazing). You can also try www.autobody101.com. Ask the pro's what they use. You need to find something that wont soften the clearcoat. Dont use lacquer thinner, its too strong. If they use catalyzed enamel, you'll probably have to tape off both sides of the pin stripe and use like 3m swirl mark remover. Id ask a pro first. Repainting that is going to almost surely constitute a full repaint or at least a blend at a body line. If this is your 20yr old factory clear coat, you may honestly be best going to a very skilled paint shop since our factory clearcoat is anything but robust.
Keep us posted
Old Apr 27, 2009 | 09:47 PM
Charged350's Avatar
Car: 87 IROC Z28
try a little thinner if reducer didnt work....im a small spot try it out not a lot jus a little on a corner of a paper towel....if that dont work.,...tape it off and wetsand them off and polish it with a buffer......
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Stryker412
Sep 7, 2015 09:11 AM
