polishing my wheels
Old May 29, 2009 | 10:59 PM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
polishing my wheels
hey guys , I started polishing my wheels today, I think there coming out good.What do you guy's think
Attached Thumbnails polishing my wheels-100_0467.jpg   polishing my wheels-100_0468.jpg
Old May 30, 2009 | 03:08 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Re: polishing my wheels
..... How much time did you put in just on that one rim? Give us a little more info on what you did.
Old May 30, 2009 | 10:37 AM
eddie jr's Avatar
looks really sweet in the pic! Yes, please elaborate on what you did.....sanding before polishing? If so what grit? etc etc.
Old May 30, 2009 | 11:43 AM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
step #1: I sprayed some easy-off oven cleaner and let it sit for 30min after the 30min you scrub the with a teflon dish scrubber.By doing this it cleans off all of grime and corrosion.when your done wash off the cleaner and dry the rim.
step #2:now you have to remove the clear and paint i used Eastwood paint remover.Brush on the remove on to the rim and let it sit for 3Hrs.After the 3Hrs you scrape the stuff off or if you have a power washer that works better.
Step #3: Now it's time polish, I use 400grit sandpaper.Start sanding til the finish on the rim is dull now you rinse the rim down and wipe it dry.This process took me about 1.5hrs to do.
Step #4:now your done sanding, you grab the finest steel wool you can get and start scrubbing until the dulness is gone and any light scratches.The steel wool also give it a nice smooth finish.This process took me about 3hrs per rim depends on the shine you want it can take you longer.
Step #5:now rinse off the rims and dry it.Take Mothers mag and aluminum polish.Apply the polish to the rim let sit for about 2min and then rub the polish off and your done. You will be amazed i know i was.I couldn't believe how nice they came out.
Old May 30, 2009 | 11:51 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
They look good, now is the time for new tires.
Old May 30, 2009 | 08:25 PM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
thanks, The car is going to the bodyshop to get painted.When i get the car back thats when i'm going to get new tires.
Old May 31, 2009 | 02:28 AM
webeeZ28's Avatar
Engine: 5.7 350 B2L
Your hard work really shows off. Post some pics when you get the car painted.
Old May 31, 2009 | 10:40 PM
eddie jr's Avatar
So did you sand until the fine machine lines in the metal (from the factory) were gone?
Old Jun 1, 2009 | 12:03 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
excellent - when are you heading over here to do mine?
looks great.
Old Jun 3, 2009 | 10:54 PM
herm's Avatar
Car: 85' t/a
Engine: 305 tpi
Axle/Gears: stock i hope...
the wheels look great. i am going to have to try this.
Old Jun 13, 2009 | 06:22 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Transmission: reverse valve
dude, seriously!
I have those wheels... and they look disgusting compared to yours!
NICE JOB! I wish I had the patience and time for that. Heck, I pay someone to wax my car, truck and wife's car that's how bad I am.
Old Sep 29, 2009 | 05:43 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
They look awsome how much time did it took you for all of the wheels and do you got pics of them on the car
Old Oct 1, 2009 | 06:57 PM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
looks good. are you going to paint the insideparts of the rim? clearcoat it?
I had a hard time trying to polish a set of iroc rims a long time ago. the factory had machined groves in them that weren't obvious before i started polishing them. so extensive sanding was going to be required first, more than i wanted to do at the time.
note, if you don't use stainless steel wool, it can infuse steel molecules into the aluminum surface, and those can cause visible rust if exposed to moisture. a preferred method is to use stainless steel wool, or those 3m scrubber pads. they come in different coarseness. basically the thin green or white scrubbers you use for your fryin' pans. I haven't personally seen the rust on aluminum but have on stainless steel when regular steel wool pads were used to polish it. probably not a big problem, but just an fyi for others going to polish their wheels.
Old Oct 8, 2009 | 07:45 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
well call me informed.
i did an entire wheel with regular steel wool.
i used WD-40 as a lubricant though just to make me feel better
i was getting a lot of **** built up in the steel wool though so maybe i was doing it wrong
Old Oct 8, 2009 | 12:20 PM
brutalform's Avatar
Nice Wheels!!! Im moving this to the proper board so others can enjoy!
Old Oct 8, 2009 | 02:49 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
Real nice man, I have to polish up my GTA wheels since the clear coat is flaking off on all of them but really bad on two. This info helps
Old Oct 8, 2009 | 10:53 PM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
No clear coat?
Also, use sticky weights when you grab new tires to keep clean looking.
Old Oct 9, 2009 | 06:05 AM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Nice job.I also did mine and I will try to get some pics up.I started with an electric orbital sander with 340 paper discs and took all the factory machine marks out.Then wet sanded with 800 1000 2000 polished with mothers and put some sealer on them.They come out amazing look chrome.spent about ten hours per wheel.
Hotrodboba400
Dec 10, 2019 07:07 PM
Breazlan
Sep 25, 2015 11:20 AM
scottmoyer
Sep 7, 2015 07:06 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
