whats best to clean rims
Old Aug 12, 2001 | 09:36 PM
rusty12's Avatar
i have factory iroc rims that i cant get clean. Can anyone help?
'92 Camaro RS,V6(I just bought it)
Old Aug 12, 2001 | 10:54 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I'll give you a bump
Mine shine REAL good, but they got little stains on them I cannot get off either!
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
My IROC
Old Aug 13, 2001 | 08:04 AM
RARE-ROC-Z's Avatar
steel wool will take off those blotches on the clear. and just get some wheel cleaner and let is sit on there while you mit your car (spray the wheels first when you start washing) and then spray it off near the end, and wipe down the rim with a cloth, this should keep it clean.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Dupont Flame Red Hardtop/ Grey Interior
Working at Carl Cleve & Sons Auto Body Repair as the wetsander/buffer.
1991 GREY S10 2.5L/5SPD -FOR SALE.
Old Aug 13, 2001 | 09:24 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I find that Quicksilver II wheel cleaner works great, plus some kind of brush that can get in the small spaces.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 13, 2001 | 10:26 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
If your rims are clear coated, and you use Zaino, Z2 does wonders on the shine.
Third Gen Project
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
"Stock?! Theres nothing "stock" about a stock car."
Old Aug 13, 2001 | 11:35 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Fast Orange hand cleaner-it works wonders.
Old Aug 13, 2001 | 03:40 PM
ATOMonkey's Avatar
Has anyone ever tried cleaning the inside of the wheels? You know, where there is 10 years of brake dust and dirt caked on. I found the most toxic stuff I could(No contact with skin, use in a ventilated area, etc.) and sprayed it on and let it soak for a couple of hours and brushed it off, it helped a lot, but they're a long way from clean. I did this when I was buying new tires, so I wasn't worried about the old ones. I don't think it even possible to get them clean anymore.
Old Aug 13, 2001 | 06:35 PM
87firebird's Avatar
fast orange with pumice. and steel wool
Old Aug 13, 2001 | 07:20 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Don't mean to make this sound too easy, but Turtle wax wheel polish will take it off in a heartbeat. I never thought my wheels could look so good.
Old Aug 13, 2001 | 11:40 PM
zee28's Avatar
Car: 86 iroc
P21S wheel cleaner is the best ive seen.its more expensive but worth it.you can get it at autodetail.com,topofthelineauto,etc.
~mike~86 IROC-Z
Old Aug 13, 2001 | 11:43 PM
zee28's Avatar
Car: 86 iroc
for the guy who wanted the back of the rims cleaned.I did mine and used the P21S and then polished them for about 3 days with mothers.The trick now is keeping the dust from building back up which involves taking them off once a month and cleaning the backs.
~mike~86 IROC-Z
Old Aug 14, 2001 | 12:43 PM
rusty12's Avatar
thanks for the info guys
Old Aug 14, 2001 | 06:53 PM
NHcamaro's Avatar
instead of steel wool try a little brass brush..you can then at VIP etc..I got a kit with 3 brushes. 1 brass 1 steel 1 plastic. I got the ones with a round tip works get for getting into tight places.
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
AOL: RyanNH84
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
