Picture request: 4th gen rear end with stock 3rd gen wheels
Old Aug 15, 2009 | 07:33 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I am thinking about selling my ZR1's and tires to help pay for my T56 for my LS1 swap, and in order to do that I would have to put the stock wheels back on the car. I have a 10 bolt from a 2002 Z28, and I know they would stick out a little more than usual. Does anyone have a couple of good pictures that show just exactly how much the stock wheels would stick out on a 4th gen rear? I'm really curious...I'm thinking with a 500hp LSX under the hood with the stock wheels and virtually a 100% stock looking car it would make for a SUPER sleeper.
Old Aug 15, 2009 | 08:32 PM
Stephen's Avatar
Car: 87 GTA
Re: Picture request: 4th gen rear end with stock 3rd gen wheels
Stick out farther than stock, yes. Stick out past the fender, no. And yes.....Stock wheels.
Old Aug 15, 2009 | 09:10 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Sleeper for sure but im not sure you would get much traction with 500hp.
Old Aug 15, 2009 | 09:21 PM
Stephen's Avatar
Car: 87 GTA
Send the stock wheels off to be widened and put wider tires on them. First look & nobody will notice.
Old Aug 15, 2009 | 11:45 PM
BlueZee28's Avatar
No way in heck I would spend that much money on the stock wheels. I hate the way they look but at this time I can really use the money for a tubular k-member. I'd like to get some chrome C5 Z06's later down the road with 11's out back.
Thanks for the pictures by the way!
Old Aug 15, 2009 | 11:53 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
The outer wall of the tire will be DEAD EVEN with the outermost edge of the fender flare.
Old Aug 16, 2009 | 09:44 AM
BlueZee28's Avatar
It doesn't look as bad as I had it pictured in my head. I was thinking the tires would go PAST the fender lip. That would be tacky...
Maybe I'll really consider doing this now. Does anyone want some 17x9 chrome ZR1s and tires for $550?
Old Aug 16, 2009 | 10:05 AM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
93 to 97 rears are actually wider than the 98-02 both wider than stock but 93-97 being the widest i wanted one out of a 01 ws6 bad but has afraid to run my stock iroc wheels at what it would look like or even rub the top of fender with 4 people while cornering
Old Aug 16, 2009 | 11:17 AM
ssean92's Avatar
Car: sold
One thing you have to remember Nick is you are lowered, those cars didnt look lowered
Old Aug 16, 2009 | 11:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Old Aug 17, 2009 | 10:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
They will rub when lowered - mine do - ESPECIALLY with 4 people in the car! But I'll never have 4 in mine - don't know 4 people I like that much! I'm running Eibach ProKit (1" drop), stock 16" wheels, and 245/50 R16 tires on a 1999 LS1 rear, and I will rub rarely with only 2 people (bad dips in road). And if I load like 80 lbs of camping gear or something, I'll rub.
I'm going to get some airbags for inside the coil springs soon, to help combat this, as I plan on a sub box as well, and that's going to be heavy also. It's not the outer fender that rubs, it's the lip up inside the edge - my last set of tires you could see a small cut in the rubber where I had rubbed a couple times - just about 1/2 inch in on the tread.
My RS looks just like the black IROC above as far as how the look is.
Old Aug 18, 2009 | 07:04 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Oh wow, totaly not what I expected. Doesn't look bad at all.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
