car cover?
Old Aug 13, 2001 | 12:30 PM
blackstripes's Avatar
car cover?
my car is going to be sitting in my garage for about 4 months and its not going to be driven at all. im looking for a cheap cover to buy that will fit the car ('92 camaro), and that will keep the dust off of the finish. does anyone know where i can get the cheapest cover for this? i don't really want to spend $100. Also, do i need to do any kind of prep or anything before letting my car sit that long? engine wise? thanks
-pat
Old Aug 13, 2001 | 02:36 PM
ATOMonkey's Avatar
The cheap covers from your local auto shop don't do squat. I know from experience. As far as the engine, 4 months is nothing. It'll do that standing on its head. Just make sure the coolant mix is right, and that the oil is ok before parking. I have to store mine at least that long every year.
Old Aug 13, 2001 | 08:09 PM
pmalski's Avatar
As for storage, fill your tank with gas and add fuel stabalizer. You don't want that gas to go bad and gum up your fuel system.
I have seen cheap covers at Auto parts stores for $35 to $50. You may want to invest in a better quality one, however.
Patrick Malinowski
1991 Z28 Convertible
25K original miles.
1998 Honda Accord Daily driver (hey it has got a 200 hp V-6 and is better in the snow)
2000 Impala (wife's)
Old Aug 13, 2001 | 08:34 PM
camaro chick's Avatar
Try to siphon out gasoline if at all possible (if not use the stabilizer) as gasoline begins to break down after approx. 3 months. Turn engine to TDC. Your engine will be fine. As far as covers go- park it the garage (if you can) or in the basement (like I do)!
Old Aug 13, 2001 | 09:49 PM
un4givin89's Avatar
May depend alittle on your climate too, if your up north you may not want some cheap *** cover that will get brittle and ruihn in the freeze and low temps.
Old Aug 13, 2001 | 10:18 PM
82camaro's Avatar
Car: 82 camaro SC
If it's in a garage, all you need to do is keep the dust off of it. Don't have to worry about weather and stuff. I use a cheap wal-mart cover in the winter months and once in a while in the summer. I wash the cover once in a while and always put the cover on when the car is clean. The next summer it looks just like it did when I put the cover on.
Why store it at TDC. I'm assuming you are talking about cylinder #1. Sure the valves will be shut on that cylinder, but others will be open. It doesn't matter where the engine is at, some valves will be open and some shut no matter what.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 13, 2001 | 11:04 PM
Amrish's Avatar
This is to: un4givin89
I am going to college, and my roommate is from virginia beach to, i just wanted to know if u know a kid named tyler. If you do, please drop me an email at:
ampatel1@freeze.com
If not, then thx anyways for reading this.
1992 z28 25th Anniversary
All black w/ z28 wing
Flowmaster Exhaust
350 TPI
Old Aug 14, 2001 | 01:09 AM
i should have been more specific, i do have a spot for it in the garage, so i am not worried about rain/snow. all i need is something to block the dust. essentially i want to wash, wax, and cover this car the day before i go to college, and when i get back home for break, i want to be able to take off the cover and have it be just the way i left it.
82camaro, that wal-mart idea sounds good, is that cover custom fit for your camaro or is it just a generic cover? how much did it cost? does it block dust?
Anyone else, what is TDC?
-pat
Old Aug 14, 2001 | 02:44 AM
Jza's Avatar
Jza
Just another tip:
Put the car up on stands or blocks, but under the control arms and axle. This way the suspension is still loaded (don't want it to hang down for that long), but the tires are off the ground so they don't develop a bruised spot from sitting on one place for so long (vibrations later that no balance job can fix).
I saw that in Motor Trend, I think...
Old Aug 14, 2001 | 07:00 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I got a car cover for mine, picked it up from the dealer.. 160 bucks canadian, so it shouldn't be to bad down in the usa.. plus it fits the car like a glove.. Plus it says camaro on it.. it's made from the Dupont Tyvek material, heavy duty..
89 RS Camaro, LO3 305 TBI
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
Old Aug 14, 2001 | 08:53 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
You can get a cheap car cover for $20 at Walmart or a higher qualoty one for about $50.
I bought the cheap $20 one and it wroks fine in keeping the dust and sun off of it.
Manny
92 Bright Red z28, 350, 47k miles, pw, pl, power mirrors, power drivers seat, rear defroster, limited slip performance axle, 4 wheel discs, red leather interior and the Heritage Package!!
Old Aug 14, 2001 | 10:14 AM
82camaro's Avatar
Car: 82 camaro SC
The wal-mart one is 'semi-custom', that is to say it fits other cars about the same size. It fits just fine and blocks all the dust and stuff. My garage is just off a dirt road so the cover gets covered in dirt. I've had it for at least 3 years(probably more)
82camaro
Old Aug 14, 2001 | 10:38 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I don't know about you, but I take my car to college... There's plenty of 80's mudstains ther and not many F-bodies... gotta represent... plus the chicks dig fast cars>
A dirt cheap car cover will work just fine to keep dust off, but so will a couple of bed sheets... just my $.03
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!!
First Kill: 2001 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
Old Aug 14, 2001 | 01:17 PM
colinfinkle's Avatar
http://www.calcarcover.com/default.asp
Nothing but good things coming from thic company! I am sticking one on the car when old man winter comes.
Colin Finkle
87 Sport Coupe Camaro, 5.0 L V8
Old Aug 14, 2001 | 02:42 PM
ive been to www.calcarcover.com but right now i cant justify spending over $100 on a car.
-pat
Old Aug 18, 2001 | 11:35 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Last fall I bought one of those cheap $30 covers. It held up ok through the winter, but with the intense heat and acid rain, it got dstroyed. It has become very thin and brittle, so it's time for me to get a new one. I knew I was in trouble when I saw blue stuff on thee ground in front of the car.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 01:18 AM
