hatch needs to look pretty
Car: 92 rs
Engine: 3.1l v6
Transmission: stock
Axle/Gears: stock
hey what do i do with these rusted peices? can i buy just covers or do i sand them down and chrome them?
heres an img
heres an img
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: hatch needs to look pretty
Wow - those are pretty bad. I might hunt eBay, thirdgenranch, hawks, or somewhere for new ones. Otherwise, if it were me, I'd cut away the leftover rubber and paint them black.
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
trim the gunk away, tape around the heads with painters tape (on the glass) sand with some 320 grit, vacuum up any dust, wash the car with plenty of water to keep the rust dust away. Wipe the heads with a clean lint free cloth and some paint thinner or mineral spirits/alcohol. tape around everything, cover your roof and fender with a sheet and spray with Duplicolor Trim Paint in a rattlecan. Id also mask off the metal edge that goes around the edge of the glass, scuff with 600 (wet this time) and 2 very light coats of the trim paint.
Nate
Nate
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
they look pitted beyond repair. just get some different ones. taking the hatch off isn't that hard, do it right the first time.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Wow, that sucks. Should be able to get a set at a local junk yard. Much easier to replace them. The plastic covers probably eroded over time leaving the metal underneath to rust.
Car: 92 rs
Engine: 3.1l v6
Transmission: stock
Axle/Gears: stock
so i cant find a junkard near me with a camaro do you know what the name of the bolt is so i can search online and try it that way?
Car: 1992 RS
Engine: Carbed 350
Check with 1ATony on here - send him a PM - they carry alot of Camaro Parts. Send emails to folks at www.hawksthirdgenparts.com, www.thirdgenranch.com and ask them. Also check with eBay sellers camarocentral, gmclassicparts, rachetman, am-autoparts - these sellers usually have alot of thirdgen stuff.
Engine: V6, V8
Did you check for Firebirds as well as Camaros?
The dealer would also be a good place to find one. They can pull up a diagram and get a part number and name that way. They can do this over the phone. Some dealer prices aren't too out of line while others can be excessive.
Car: 89 IROC-Z
If you need the part # let me know i have all the service and parts manuals.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
they look nasty , replace them . try and find new ones , replace one at a time . be careful , do one at a time . clean and go slow . use sealent , do not over-torque . you may need a new glass if you do . good luck .
i was just checking M.D.M. ( modern day muscle ) site and found them new . they are $8.49 ea. , a little pricey but new . should last another 20 yrs. if sealed and installed correctly . good luck .
Car: 92 rs
Engine: 3.1l v6
Transmission: stock
Axle/Gears: stock
where did u find them can u link it? every parts website i've talked to said i need a new hatch and they want like 250. hawks was the cheapest at 250.
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
http://www.moderndaymuscle.com/inc/sdetail/858
good call Tom
but dang you buddy, now i found some stuff i need to buy
good call Tom
Engine: V6, V8
Many places with Upulls sell hatches for around $30. We have had people that ended up throwing them out because they can't get rid of them and they take up too much space.
Car: '86 Camaro Sport Coupe Berlinetta
http://cgi.ebay.com/ebaymotors/82-92...=p4506.c0.m245
I actually just replaced them on my car and it looks so much better
I have some new ones to replace the rusted ones on mine, but is there a trick to getting them off? I tried unbolting them, but they just turn and turn- I thought they would be locked into a square hole in the glass or some such...
Can someone give me some pointers on removing the old ones and installing the new(sealing, torque settings etc)?
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Randomtask2
Sep 10, 2015 08:37 AM
