Camaro Parking Light Question? Help!
Old Sep 24, 2009 | 11:05 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hey everyone, I have a question for you guys any advice will help ok, here it goes First of all I just love how the 4th gen parking light always stays on no matter what when the car its on. Like when I put my my parking lights on there are not as bright but when the turn signals are blinking there real bright what can I do to do this mod or do you guys have a suggestion on how to achieve this and/or is it a good idea?
Thanks. Tony.
Here's a pic for example.
Old Sep 24, 2009 | 11:25 PM
Engine: 3.0L 2JZGE
Re: Camaro Parking Light Question? Help!
Once again any info would be great.
Thanks. Tony.
Old Sep 25, 2009 | 12:06 AM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Possibly get DRLs but wire them to the parking lights rather than high beams??
Old Sep 25, 2009 | 12:11 AM
Engine: 3.0L 2JZGE
What do you mean by DRLs and wire them to the parking lights? Im not sure what you are trying to tell me.
What I want to figure out is when the car is on the parking lights turn on automatically like the 4th gens and there nice and bright like when you have the blinkers on. Like hen you pull the headlight switch in the middle they turn on but there not as bright though, I want them to be bright like when you are having the turn signal on.
Thanks. Tony.
Old Sep 25, 2009 | 11:53 PM
Dennis-Z28's Avatar
The canadian cars from like 1991 on had Daytime Running Lights (DRL) which made the high beams turn on whenever you drive (reduced power but still high beam). If you could install that you may also find a way in the wiring diagrams to have the parking lights used for that function instead of the high beams. Take some reading but it sounds possible.
Old Oct 24, 2009 | 02:30 PM
Engine: 3.0L 2JZGE
Man I havent had time to try my idea out I was thinking what if I get a brighter bulb or so? I wonder if the ones that some on the 4th gen's might work on our cars?
Tony.
Old Oct 24, 2009 | 03:23 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
I was going to PM you and see if you found a solution. Heres what i think is going on. I just have to see lol. The parking lamp bulb in our cars has 2 elements. When you turn the blinker on in the day only 1 element lights up. When you turn the blinker on at night 2 elements light up. So in the day its not as bright as it would be at night. Now that I understand little more what you would like to do its gonna be pretty easy to wire the circuit let me check the lights on mine and I will draw or write what to wire for you on your car.
Old Oct 24, 2009 | 04:22 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Here's a site where the author did this to his '75 Duster. Complete with step-by-step instructions. All you would have to do is figure out the wire color for the GM circuits in question.
http://www.allpar.com/fix/electrical/DRLs.html
And this is the module he used.
http://dastern.torque.net/Mods/DRL/DRL1.html
Old Oct 25, 2009 | 08:07 PM
z28 TPI's Avatar
Okay so I looked at the parking lights in question today. Now i understand what you would like to accomplish. It works out to be switching the wire that goes to the parking element with the wire that goes to the turn signal element. And then figuring out which wire or wires are coming off the headlight switch for the parking lights in the front and running them to an ignition on power source.
Old Oct 27, 2009 | 08:37 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
someone made a thread on it on here
Old Oct 27, 2009 | 11:10 PM
Engine: 3.0L 2JZGE
Hey bro, all I want besically is to have the parking lights way brighter. I dont mind pulling the headlight switch that doesent bother me at all. Like if you put a 3rd gen and a 4th gen together and have the parking lights both on you'll notice that the ones on the 4th gen are way brighter then the ones on the 3rd gens. I just want them to be more bright and more orange and more visable.
Thanks. Tony.
Old Oct 28, 2009 | 01:09 AM
Al Hasse's Avatar
Thanks. Tony.
That's what this module in my post above does.
Old Oct 28, 2009 | 01:15 PM
Engine: 3.0L 2JZGE
Hey Al Hasse,
Thanks bro for that info, have you done this mod to your car? And if so did it work? And also where can I get this module that you have posted above?
If you want go ahead and PM with futher info.
Thanks. Tony.
Old Oct 28, 2009 | 01:48 PM
Al Hasse's Avatar
I have not done this, but looks pretty easy as far as wiring goes. Contact info for acquiring this is in the second link in my first post.
Old Dec 29, 2009 | 03:09 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I like this idea. I don't care so much for having DRL's, but I do like the idea of having the running lights run on the dual filaments and blinking to the single or no filament when the turn signal is activated. is there a way to have the DRL module only turn on when the light switch is in the running light selection? I'd like to have the dual filaments lit with the tail lights.
Old Dec 29, 2009 | 06:15 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
interesting DRLs
try this site
http://www.webelectricproducts.com/products.htm
Old Dec 29, 2009 | 07:38 AM
Engine: 3.0L 2JZGE
Originally Posted by KITT1983
Thanks. Tony.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
