How to get brand new tail lights... for FREE!!!
Old Dec 30, 2009 | 11:32 PM
ThreeOhFive's Avatar
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
I'm hoping this will be a sticky :P
I posted last night asking a question about how you can make your old, high mileage tail lights look like they did the day your car rolled off the production line, but didn't get the answers I was looking for. Today I pulled the tail lights off of my Camaro and brought them home. I decided to only do one tonight to show a before/after.
This is what I did:
1. Filled up a bath tub with enough water to submerge the lamp fully.
2. Let the lamp sit in the tub submerged for about 30 minutes.
3. Added a mix of Simple Green cleaning product and RV Gel Cleaner to the water.
4. I poured some RV cleaner and water into the bulb holes in the tail lights and swished it around.
5. Violently shake the tail light side to side, swishing the water and cleaner around inside the lense.
6. Submerge the lamp in water again and repeat step 5 a few more times.
7. This step is optional, but I gave it a shot... find an old toothbrush and try to scrub any build up from condensation.
8. Drain the tub, fill it up with clean water.
9. Submerge the lamp in the water again, and move it around in the water to make sure that the soap gets washed out, as you don't want a haze left in the lense.
10. Grab a hose and spray the lamp, I did this just to make sure there was no soap left over.
11. Wait for it to dry. You can use a hair dryer to speed up the process. You tail light will most likely look cloudy and not much different for about an hour, this is condensation.
12. Get a plastic shiner and shine up the outside of the lamp.
13. Enjoy your amazing clean, brand new looking tail lights and pat yourself on the back for saving yourself hundreds of dollars over buying new tail lights!!!
This is the difference it made with mine! The top one is not cleaned, the bottom one is...
Old Dec 30, 2009 | 11:46 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: How to get brand new tail lights... for FREE!!!
Wow, they look pretty good! Nice work...
Old Dec 30, 2009 | 11:59 PM
Engine: M54 DOHC I6
Axle/Gears: Stock
Thanks! I think the biggest difference was in the reverse lights, but I've noticed the brake and signals look MUCH clearer, too.
Old Dec 31, 2009 | 12:08 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Dang i am gonna do this to mine and then paint the amber red i was thinking of sanding them and just polishing but your way sounds much easier
Old Dec 31, 2009 | 12:12 AM
Engine: M54 DOHC I6
Axle/Gears: Stock
It is, I didn't even have to disassemble them! It takes very little time, sanding would be much harder to do! If you do try this, please post pics, I'd love to see how everyone else's turns out! After all, I think our tail lights need to look good... that's what 99% of the other cars on the road are going to see
Old Dec 31, 2009 | 12:18 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Yea, sure but i am not gonna do this probably till april since that is when i am going to paint my car, also was the water hot or cold and also what is the rv gel cleaner and were can i find it
Old Dec 31, 2009 | 12:24 AM
Engine: M54 DOHC I6
Axle/Gears: Stock
I'd definitley start with cleaning them like I did, see where that gets you. We're painting our '92 also. Can't wait to put all this redone stuff on!
The products I used:
Old Dec 31, 2009 | 01:02 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
i just ran mine with some never-dull. that ***** amazing
Frozer!!!
Jan 19, 2024 04:55 PM
my86bird
Oct 23, 2015 12:20 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
