Restore all your lights and anything else plastic on your car for $10 !!!
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
So check out what I used to restore a TON of stuff on mt car. But before I tell you what I used (prepared to be amazed) here are some pics.
Start with the black tail light piece thatsits on either side of the licence plate, right side is polished . Left side is what I started with . Took 20 seconds with no sanding or clear coating.
Next , although its kind of hard to tell, is the front turn signal. Left side polished , right is not. I plan on polishing these multipal times , even though the first time made them look new.
Tail lights also got it. Driver side is sun beaten and un touched. Pass side is polished .
Here is my top piece to my tpi intake. I polished that little circle . All around it is untouched .
Now most of the stuff I did so far was done with a shop rag of micro fiber towel . I still want to do several passes over each item just for the hell of it. I am just amazed how this stuff works and what you can use it on. SO, ready to find out what I used ,
*hold your breath*
Shazam ! This mothers mag polish is amazing . It brought a shine back to everything. I plan on doing my TPI stuff, as well as a ton of other plastic and metal parts . This stuff is worth every penny.
*hold your breath*
Car: 92 rs 25th anniverssary
Engine: 305 carbourated
Transmission: t-5 5 speed
Re: Restore all your lights and anything else plastic on your car for $10 !!!
where do you buy that from b/c it looks great
Car: 84 Camaro Z28
Engine: 355 Carb
Wow that looks great I am gonna see if I get one and do it to my camaro. Also I like the way you set up the thread really cool
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
looks very good . another off the wall product that i tried once before is BRASSO metal polish . the results were great . good job on your stuff .
Engine: 5.7 TPI
You can get this stuff at any auto parts store . Just thought I would share since it worked so good for me . I will post picks of the stuff when Im done too.
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
AMEN! That is a great product - I've used it for years on all of my cars! Does wonders on just about every surface! Makes a good set of chrome rims light up!
Car: 1989 GTA
Engine: 5.7 350
real nice man. Looks like i got myself a little spring break project.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I've used this stuff for just about EVERY surface i've needed to polish for years.IMO there's nothing better.
Car: 1985 IROC-Z28
Engine: 305 HO (L69)
Transmission: Rebuilt T5 (updated T5 parts)
Awww........ I was hoping this would help a cracked dash. But good info btw.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
