Tarnished Aluminum Wheels(solved)
Old Aug 23, 2010 | 10:38 AM
91_fbird's Avatar
Car: 91 Pontiac Firebird
Engine: SMall Block 350 TBI
Transmission: 5-Speed
Axle/Gears: Stock(for now)
When i first got my 91 Firebird my wheels where very tarnished and dirty looking and with the proper materials and tools i have them gleaming as if their brand new. These are the before and after pics. I think the difference is significant and could possibly save money in exchange for about 2.5 hrs a wheel. The material i used were a drill wit a fine wire wheel, which was use to remove the clear coating off the aluminum. Bucket of soapy water and 220 wet/dry sand paper, to remove and significant scratches made by the wire brush. The bucket and 1500 wet/dry sand paper to polish the surface and remove all blemishes. Dry then a bottle of metal polish and two rags.
Attached Thumbnails Tarnished Aluminum Wheels(solved)-2010-08-22-17.19.13.jpg   Tarnished Aluminum Wheels(solved)-2010-08-22-18.57.41.jpg   Tarnished Aluminum Wheels(solved)-2010-08-22-18.27.58.jpg
Old Aug 24, 2010 | 01:18 PM
401kfirebird's Avatar
Car: 1992 Firebird
Engine: LO3 305
Transmission: 5 speed
Axle/Gears: 3.08 limited slip
Re: Tarnished Aluminum Wheels(solved)
very nice work! looks 100 times better. just goes to show you that hard work and sweat pays off in the end.
Old Aug 24, 2010 | 02:23 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Nnice!!
Old Aug 24, 2010 | 03:54 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
Wow. You just saved me money from new wheels. I am going to copy cat your method.
Old Aug 24, 2010 | 05:15 PM
91_fbird's Avatar
yup it takes about 2.5 hours each but thats dependant on the condition on the wheels. and while your using the wire brush and drill to remove the clear coat keep in mind that te clear coat warms up and smears a little so you gotta let it cool off to rip if up.
Old Aug 24, 2010 | 08:55 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
just a thought , bare aluminum will corrode/tarnish pretty fast in normal conditions . clearcoat , wax , or something will be needed to protect finish . good luck .
Old Aug 24, 2010 | 09:20 PM
91_fbird's Avatar
o yeah of course i have the one wax already and im lookin for a good wheel clear coat...somethin that wont fog or turn yellow(ewww)
morrow
Jan 13, 2024 12:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
86IROC112
Sep 29, 2015 04:07 PM
