Exhaust Cleaning
Old Oct 27, 2010 | 09:20 AM
StephenS's Avatar
Car: 1991 Z28 Camaro Convertible
Engine: 1988 305 TPI
Exhaust Cleaning
I have a full Hooker Exhaust kit on my camaro. Most of the pipes have some rust and i've tried getting it off with rust remover but nothing seems to work. Is their any other way to remove the rust and bring back the chrome shine they had?
Old Oct 27, 2010 | 02:59 PM
TorqueWolf's Avatar
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
Re: Exhaust Cleaning
you might try a roll of that 1500 grit sandpaper with lots of water. use the long strip thats the tear off kind and wrap it half way around the pipes then pull it back and forth kinda like buffing a shoe. other than that steel will inevitably rust. you will need to coat it with either ceramic header paint or it will eventually rust again.
Sorry but there isint an easy way to have a chrome like shine on exhaust without spending tons on a stainless system then buffing it out. most all coatings or rust preventatives will burn off of hot exhaust tubes. thos that dont usualy have a rather flat finish.
Old Oct 27, 2010 | 03:12 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Are they ceramic coated?
Old Oct 27, 2010 | 04:23 PM
StephenS's Avatar
I don't know anything about them except that their hooker exhaust, X piped, and have 4 heads out the back. 2 on left 2 on right. They had a metal color till i tried some chrome polisher and that made a huge difference! But a lot of rust is still caked on there. I tried steel wool but that didn't work, i tried some sand paper and some came off. I'll post some pics of the pipes if you want.
Old Oct 27, 2010 | 11:31 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I havent cleaned headers but with my chrome exhaust pipes I used a crunched up ball of aluminum foil and some coca cola. It works alot better then the leading chrome cleaner. Plus it removed all the rust! The coke helps with removing the rust as it is sort of acidic (thats why it rots your teeth!) and the aluminum foil brings out the ions or something to remove the rust and bring out the shine of the chrome! Oh it gets kind od sticky so when you are done you might want to rinse them off unless you like the smell of burning coke!
Old Oct 28, 2010 | 12:24 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
pic?
Old Oct 29, 2010 | 01:12 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I would recommend just taking them off and sending them to Jet Hot coatings. It's a night and day difference (both in appearance and under-hood temps.)
Old Oct 29, 2010 | 08:14 PM
FueledSoul's Avatar
If his going to go that route id just sell them as is and buy direct from jet hot.
Old Oct 29, 2010 | 08:54 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
A light/medium steel wool probably would have worked the best. I use it to get the carbon builld up off of my exhaust tips.
Old Oct 30, 2010 | 09:00 AM
StephenS's Avatar
Well I don't have the money to get them taken off and sent to be cleaned. I got some of the metal color off but it doesn't seem to stay chrome for a whole week. It gets dirty again in a few days. And now i just realized that my tips are covered in black stuff on the inside. I'm assuming its obviously from the exhaust fumes.
Street Lethal
Apr 30, 2019 12:14 PM
deracer
Apr 11, 2016 12:04 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TheExaminer
Aug 26, 2015 04:59 PM
