88 GTA just getting started
Car: 89GTA, 62' GSXR1000-SS
Engine: 406-HSR
Transmission: Nocturnal
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: 88 GTA just getting started
One question: Why are the times so high when you have a 406 HSR in it or are those times on a 350? Mine ran 14.25@96 and all I had at the time was a 350 with a SuperRam on it and some bolt ons/upgrades.
Engine: 406-HSR
no the 406 is in progress as im typing lol.. that pass was just bone stock with dynomax exhaust y-pipe back
Engine: 355
Transmission: 4L60
Accel/Lingenfelter Super Ram intake
24 lb Bosch design III injectors
Accel 58 MM throttle body
PCMforLESS tuned chip
160 degree thermostat
Flowmaster 3" from Y pipe to muffler
Goodyear hi miler hoses
EGR deleted
TB coolant bypass
NGK G power plugs
Taylor 8MM wires
Hypertech cap and rotor
Hypertech 53K volt coil
K&N air filter
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
From what I have seen browsing the forums for the past two years, a stock L98 does mid 14s, low 14s with a good driver.
Engine: 355
Transmission: 4L60
I have read all the magazine articles posted over on the source page and everything I've read says the GTA does high 14's generally from the factory. I can imagine mid 14's, but 14.2 is just pushing it for me on a stock L98 from what I've seen and read. I'm not calling his word into question, I'm just curious on why I'm not faster than that given my mods. I dynoed at 235WHP and 318 WTQ which is about 40-50 HP over what they made from the factory when you factor in the driveline losses, so how the hell am I only running with a stock 88 GTA that had 15 HP less than me from the factory since they were rated at 225 and mines rated at 240?
Engine: 406-HSR
is yours an auto or t5.. my best 60 ft was 1.97 launching about 1k or a lil over.. i tried to run in with 87 oxygenated fuel compared to 93 pump that i had.. and i picked up a .10 at the 1/8th.. i know a guy with air foil and y-pipe back, k&n, and 10* advanced timing but he has a 2800 stall in an iroc an run high 13.80s
Engine: 406-HSR
Engine: 355
Transmission: 4L60
Here is my timeslip: http://www.dragtimes.com/Pontiac-Tra...lip-21008.html
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
his first post,
***edit****
hahaha, opps my bad, didnt see the second time
but yes, i have seen l98's go low 14's with little work
The_Phoenix
Feb 4, 2016 07:10 AM
