Wiper Mod- reversed
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Car: '91 TA vert
Engine: turboLSx
Re: Wiper Mod- reversed
I think I remember a post from you about this years ago. Do you have pictures of how you mounted the extended linkage/passenger side mount?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I cant remember ever posting about this, but who knows!I did this mod back in the early 90s.Long before i joined TGO.
Anyway, no pics.I used a driver side wiper arm(modified) & base.Plus an extra linkage to reach the pass side.Only using one nozzle, mounted in the center.
Car: 86 IROC
Engine: 305 carb
Transmission: 5 speed
I used a driver side wiper arm(modified) & base.Plus an extra linkage to reach the pass side.Only using one nozzle, mounted in the center.[/quote]
Man, can you share the details on this one. my neighbor thought i was nuts cause i was cussing so much trying to figure this out
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Details are a kinda fuzzy.I know the wiper arm is a driver side.However the angle is wrong when its switched to the pass side.So the flat piece has to be seperated from the lower half of the wiper.There is a rivet that needs & a strong a$$ spring that need removal.Once you seperate the flat piece, rotate is 180* so the angle is correct.If you dont do this mod the angle will have the wiper blade pointing up.
The base the wiper mounts to Im pretty sure is a driver side unit.I had to drill a hole on the pass side cowl to mount it.Plus three smaller holes for the bolts.Make a template of the mounting surface using the base.Then trace the template onto the cowl.
The extra linkage used is the same as the longer of the two already on the car.The side that connects to the original linkage has several small holes drilled so the adjustment can be dailed in.
The main problem when i finished, was the wiper arm had too much travel & the blade would swing past the B pillar & also slam in to the cowl.I remember having to change the length of the arm on the base.To reduce the travel on the wiper arm.I think a had to make the arm longer, but i dont remember by how much.I had to play around with different lengths though.
Thats about it or at least, all i can recall.
Car: 86 IROC
Engine: 305 carb
Got the second assembly today and did the 180 on the second arm. Drivers side base is round, pass has this piece that looks like a block for the arm( just making sure I'm using the right pieces) How do the two linkages hook together? Seems like everything still goes in the original directions.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Oh yeah, forgot about that.I had to remove the splined head by grinding of the top, then rotate it 180* as well.This is so the step on the head alignes with the notch on the wiper body.My base is mounted the same way as the driver side(2 bolts pointing out,single bolt inward).This puts the base at a good angle, but the step facing the wrong way.If you just rotate the splines 180* the arms for the linkage hit the firewall.
Your gonna have to play with the position of the step.Dont want it too low or high.Once you have the travel worked out.You can center punch the the top of the splined head.So it wont slip off.
On the linkage.I used a 1/8 bolt w/a nut.Drill one hole on the original linkage & 5-6 holes about 1/16 apart on the 2nd linkage.This is what i used to dail in the adjustment.
Probably more i need to remember.Ill take pics, its easier.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
OK, seems i did things a little different still.The arm the link connects to is from the pass side wiper mount.The driver is a dual sided piece & this is a single.I probably had clearence issues with the dual sided arm.So i used the pass side piece.You can also see i shortend it, maybe 1/2 inch.This was done to reduce the amount of travel the wiper has.Other wise it swings past the b-pillar.Two bolts to hold the two halves inplace.This is wayyyy before i had a welder!You still use the round head w/splines as described above.
Wider view.
On the link it appears i used two bolts, instead of one.Also i slotted the hole in the upper link, instead of the 5-6 holes i thought i drilled.The stock link has just one hole.One bolt wont work, because the link will flex when the wipers are used.
Wider view.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Car: 86 IROC
Engine: 305 carb
Are the two halves on a 90*? I'm not a welder or a fabricator, so Im trying to make sure I get this right. This is my very first mod.
Car: 86 IROC
Engine: 305 carb
Two halves are cut, moded and ready to be welded. Can you post a pic(top view) of were the pass side is mounted. Getting ready to cut.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Make sure you have the correct length before welding it.Did you check the travel on the wiper?
Car: 86 IROC
Engine: 305 carb
having so much fun with this but i gotta job to go to lol The piece on the end that the ball joint goes into( the rubber piece) Did you bend that backwards
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
No, it only works one way.That rubber cap has a steel insert.Pretty hard to bend it.
Car: 86 IROC
Engine: 305 carb
having issues getting this thing adjusted. Full up, wipers are fine. In the down or rest position, pass side goes into the engine bay before the drivers side gets to the down positon. Think it has something to do with the links under the pass side.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Did you make sure the arm is the correct length before welding it?Sounds like you have too much travel still.Which means make the arm shorter.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
That's pretty cool. I might try to do that myself. You've got a lot of awesome mods!
Car: 86 IROC
Engine: 305 carb
ya know what 1LE, I didn't do anything to the arm. Once hooked up I made sure it all had the right direction of travel. I adjusted the pass wiper so it was straight up with the drivers side. Turned the wipers off so they would be in the full down position and thats when the pass side travel was shot to he!!..... so I'm guessing I need to shorten the second arm 1/2 inch or do you have an over measurment of what length the second arm should be?
Car: 86 IROC
Engine: 305 carb
@rubberduckey check out the very first post from 84 1LE. He's got a video link that shows the low and high settings. It works really well. This guys knows his sh t
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Car: 86 IROC
Engine: 305 carb
any trips to phoenix in the near future? lol a friend of mine was helping me and he went crazy. couldn't get the splined piece off, so he just removed the whole base,grinded the ring off the bottom on both. now ive gotta start over
maybe I'll get this done sometime next year lol. still a cool project. PM me if any suggestions Thread
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 01:00 PM
