Any pics of thirdgens with wide rear quarters
Old Dec 4, 2010 | 02:49 PM
91rallyss's Avatar
Car: 91 camaro
Engine: 355
Axle/Gears: 3.42:1
I was looking in to putting wider rear tires in back of my car and i wanted to see a car with wide rear quarters and how wide a tire you can fit. Any posts or advice would be greatly appreciated.
Old Jan 5, 2011 | 07:11 PM
Gen3FTW's Avatar
Car: 1985 Z28 Camaro
Engine: 385 Stroker
Axle/Gears: 4:11
Re: Any pics of thirdgens with wide rear quarters
28x11 is what Im running. The bigger rear tires really dress the car up for some reason.
Old Jan 5, 2011 | 09:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can always go in, probably "easier" than trying to stretch the quarters. Im running 18x12 wheels and 335/30/18's ont eh rear of my car, tucked like stock. required a minitub.
Old Jan 5, 2011 | 10:18 PM
Stephen's Avatar
Car: 87 GTA
I'm running 315s on 11" wheels while it required more than "minor" sheet metal work, I wouldn't call it major work by any means. And all under the stock quarter panels. Easier to go in than out.
Other than Neil's https://www.thirdgen.org/forums/body...one-phase.html (don't ask which page has a pic of them, i dunno) custom widened quarters & the fiberglass quarters from http://www.showcars-bodyparts.com/ I don't know of any other widened quarters.
Old Jan 7, 2011 | 03:32 AM
91rallyss's Avatar
Car: 91 camaro
Engine: 355
Axle/Gears: 3.42:1
Thanks for the advice. Im just wondering though when you did the mini tub or modded your inner rear quarter how do you get a tire or rim that wide without hitting your lower control arms? Do you guys have any pics? Would definatly be greatly appreciated.
Old Jan 7, 2011 | 08:50 AM
Stephen's Avatar
Car: 87 GTA
Follow the link in my sig above for pics. I even had a whole thread about it.
Old Jan 8, 2011 | 07:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
tubular control arms give you more clearance, and i had a set of offset arms made to clear my wheels. springs had to be changed out too for clearance. Gotta pay to play
Old Jan 8, 2011 | 07:55 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Stephens thread is pretty comprehensive as well as informative. You'll probably need offset lca's as well.
Old Jan 8, 2011 | 07:58 PM
Stephen's Avatar
Car: 87 GTA
I was able to get enough clearance by using off-the-shelf tubular LCAs with the offset bushing mounts.
If/When I go to 335s, I'll just see about getting new offset mounts made.
Old Jan 8, 2011 | 08:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you dont "need" offset arms to fit an 11" wheel, but you do to keep the tire udner the car (like Stephens). Most people here with 11's have the tire flush or just outside the wheel well, which is no good in my book. Anything more than a 11" wheel requires major surgery to fit properly.
Old Jan 9, 2011 | 12:08 AM
Stephen's Avatar
Car: 87 GTA
Exactly. The offset arms were due more to the 7" of backspacing than the width. If they were just 6" of backspacing but still 11" wide, I wouldn't have needed the offset LCAs nor as much wheel well cutting. That extra 1" backspacing caused extra work, but was worth every bit of it!
Old Jan 9, 2011 | 01:28 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
http://www.showcars-bodyparts.com/8292cam.html
More direct link to the wide quarters
Old Jan 9, 2011 | 01:32 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by matthufham
http://www.showcars-bodyparts.com/camaro85iroclow.jpg
Sure looks like stock fenders & quarters, even with the pic blown up as big as possible.
EDIT....You chanmged your link after I hit Quote to reply.
1992 Trans Am
May 10, 2023 07:19 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackTopKing
Aug 19, 2015 12:13 PM
Exxon Limited
Aug 9, 2015 08:13 PM
