How can I really shine my GTA wheels up?
Old Jan 11, 2011 | 10:33 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
What can I do to bring these out more?
Old Jan 11, 2011 | 10:46 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: How can I really shine my GTA wheels up?
New lugnuts may be a start. I used mothers mag wheel polish on my old aluminum wheels and they shined up pretty nice, but I am not sure how to get more out of it...
Old Jan 11, 2011 | 11:19 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
https://www.thirdgen.org/sergiowheels
Old Jan 11, 2011 | 02:05 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
I agree definitely apply fresh paint to the inner diamond spokes. They are the best third gen wheel in my opinion when at there best. Best to find someone local with some kind of media blaster to get down to the bare alum under the spoke part. Putting fresh paint over a somewhat clean wheel with undoubtably will look much improved but still a far cry from its true potential. You can achieve professional results by yourself with little $ and a lot, I say again a lot of invested time, but you need to start with a clean slate/perfect foundation.
Learn all about Eastwood polishing compunds and how to use em, Auto store bought stuff will not be true polishing.
You can go with auto store rattle can paint but thats it. And please, do not clear coat your new efforts. Few coats of wax regularly.
Also get those balanciing weights off the front. They can be applied just as effectively to the rear of the wheel. Just let the shop know. Best of luck
Here is a photo of what should be strived for. Untouched in the foreground, polished in the background. (I am not the owner of the pic)
Old Jan 22, 2011 | 12:12 PM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
I had a friend with bmw wheels jack the rear end up and put the car in gear, hold sand paper up to the rims and sanded down and polished his BBS wheels. Please don't do this.
Strip/Sand the lip first, then paint the mesh,and then polish the lip. That way you don't accidently scratch or strip the new paint while trying to polish up the lip.
Old Jan 22, 2011 | 12:27 PM
GreekItalianMan's Avatar
Car: 1986 Trans Am
Engine: lb9 305 tpi
Transmission: THM700R4
Axle/Gears: Posi-rear,3.27 9 bolt Borg Warner
I had about an inch of brake dust and 13 years of dirt and grim from my car sitting in a garage(Not being used) I used this cheap wheel/rim polish and tire cleaner(Can't recall the name but both are in my trunk) My father told me he used to wash the car with a toilet cleaner brush and wipe it down with a rag. After i washed the car and put that cheap cleaner on, used the brush, IT GOT ALL THE BRAKE DUST AND DIRT off (But, i had to spend at least an hour on each wheel to get everything spotless) It all depends on how much time you have like someone said earlier.
Old Jan 22, 2011 | 01:04 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
new lugs, new caps, freshen up the black.
Old Jan 22, 2011 | 08:42 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
mothers metal polish works wonders...
Old Jan 23, 2011 | 02:31 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
on bare metal, not clear coat
Old Jan 23, 2011 | 06:39 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
Use "Aircraft Stripper", strip the old clearcoat... polish them, use dupli-color "wheel clear".. done
Old Jan 23, 2011 | 08:13 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Until it fogs and/or turns yellow. Their wheel clear is sh-t, just about like any other 'clear coat' in a can
@Dmans85 - Those are liljayV10's wheels I did for him a number of years ago. The wheel lips were polished out with Eagle One and Mothers. The center/mesh was powdercoated gloss black.
Old Jan 24, 2011 | 07:30 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
umm no.. it depends on the prep work... 5+ years on mine
Old Jan 24, 2011 | 07:45 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
There are many posts on here how to polish Iroc and GTA wheels on this site. I personally would Use some Aircraft Stripper then wet sand with 1000 Grit or higher. Then Polish with Mothers Aluminum polish. Clearcoating is up to you. YES ive had bad experiance with rattle can clear. Turns Yellow and tends to crack. have them cleared at ur local paint shop. Or let them alone. You will just have to polish a bit more often.
Old Jan 24, 2011 | 09:04 PM
deadbird's Avatar
Engine: TPI 305/ v6
thanks...believe i have a grasp on paint prep. spray bomb paint is sh-t.
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Chuck84TA
Wheels and Tires
Sep 3, 2015 11:02 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
