Fixing bad Hvac lighting (camaros)
Old Feb 12, 2011 | 12:12 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
One of my pet peeves with camaros has been with the uneven lighting on the Hvac, especially with LEDs.Finally decided to do something about that.The light never quite reaches the switch side very well.You FB guys dont have this problem.My original idea was to just use an early FB Hvac unit, but my blue LED didnt jive with the orange FB text.So i decided to sacrafice the FB piece instead!
White dot marks where to drill.FBs use 3 #74 bulbs Vs one 194 bulb on camaros.Just cut one FB socket off & glue onto the camaro piece.
Here's my piece w/the socket glued on & the metal trim that goes below the Hvac face (drill to match as well).
Wire up one of the #74 connectors to the camaros 194 harness.
Done.Simple as that, small mod,big improvement.Wish i had a before pic to compare.
Old Feb 12, 2011 | 01:13 AM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Re: Fixing bad Hvac lighting (camaros)
cool mod man! the lighting also pisses me off lol
Old Feb 12, 2011 | 01:25 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Oh cool. I didn't even know the HVAC had lighting in my Camaro.
Old Feb 12, 2011 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Another cool light mod, 84. Looks like something that GM should have done.
JamesC
Old Feb 12, 2011 | 08:54 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I may have to do this myself too, I put a red LED in my HVAC and it's bright on one end and can't hardly see it on the other. The cluster looks good though!
Old Feb 12, 2011 | 11:42 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Im liking it.Shoulda done this years ago.
Old Feb 13, 2011 | 10:48 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
great idea bro!
Old Feb 19, 2011 | 12:02 PM
PaPaROC's Avatar
Car: 86 IROC
Engine: 305 carb
Transmission: 5 speed
EXTRA EXTRA 84 1LE has done it again.
Old Jun 19, 2012 | 11:50 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
84 1LE, I got a before picture for you. I have the same problem. Thanks to your thread, Im taking youre advice and Im gonna do the same mod. Thanks....
cc7d5281.jpg?t=1340164933
Old Jun 20, 2012 | 10:05 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats exactly how my HVAC looked before.
Old Jan 6, 2013 | 12:30 PM
THEIROCMAN's Avatar
Car: I have an 88 IROCZ. Also an 87 IROC
Engine: none, but want LS2
Transmission: none, but want 6 spd.
Axle/Gears: 88-9" not complete, 87- 10 bolt
84 1LE good info. I have 2 IROC'S the 87 is my wifes and the 88 is mine. Doing LED in and out on mine and will do this on both cars. Thanks for the info, and if I can help with something please let me know.
Old Jan 6, 2013 | 05:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks Irocman.Good to see an old thread's still useful.
Old Mar 27, 2013 | 11:10 AM
urizartommy's Avatar
Car: 1989 Chevrolet Camaro RS
Engine: 5.0
Transmission: Automatic
Axle/Gears: Stock
This has to be the coolest interior mod I have seen. ok so your car is an '84. Do you know if this same procedure should work for my 1989 Camaro RS 5.0 liter coupe? I have the same problem, but I also know that as far as interior parts go for the third gen camaro, they made slight changes here and there. Your help would be greatly appreciated.
Old Mar 27, 2013 | 06:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
See no reason why it wouldnt.Not much difference in Hvacs from a mechanical standpoint.
Old Mar 27, 2013 | 06:05 PM
Engine: 5.0
Axle/Gears: Stock
thanks, now i will go to the junkyard to get some pieces to practice on. did you splice the #74 bulb into the #194 bulb as well?
Old Mar 27, 2013 | 06:46 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, wouldn't swapping the entire face plate unit with a Bird one and swapping the face (the part with the graphics, if you don't want red/orange words) between the plates achieve the same results? Of course, you would also have to swap the fan switch, but...
Seems to me a lot of work for pretty much no reason if you already have both face plates...
Old Mar 27, 2013 | 08:02 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
...but they wont interchange!Go ahead & try it.T/As is taller & slightly shorter & the faceplates snap inplace differently.Otherwise i would have done that to begin with.
Not that much work either, unless you cant drill a hole & splice in a couple wires.
Yes, the #74 is spliced into the camaros 194 socket.
Old Feb 1, 2015 | 11:44 PM
Where the first picture? Wanna do this mod.
Old Feb 2, 2015 | 12:43 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Those missing pics are longggggg gone.I don't even have the ones still posted, sorry.
Old Feb 5, 2015 | 04:37 PM
Damn. Ok man. Didnt hurt to ask. Thanks man.
Old Feb 6, 2015 | 09:11 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
All that first pic showed was the back of the Hvac with a dot marking where to drill.You can see where that is in the 2nd pic.As well the socket glued to the back.
The other missing pic was just the f.b #74 pigtail w/bulb, spliced into the Camaro 194 bulb.
Don't remember what the 3rd missing pic was!
Old Feb 7, 2015 | 12:07 AM
So all I need is an extra plate to cut off the socket to mount a new bulb and socket connector I suppose correct?
Old Feb 7, 2015 | 12:29 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, bulb/socket/connector from a firebird.
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Apr 9, 2016 10:20 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
