Rear Side Markers
Old Mar 20, 2011 | 08:51 PM
Maroonz2800's Avatar
Car: 1987 camaro sport (Z28 interior)
Engine: V6, I6, V8, I4, I3
Transmission: auto w/OD, 5-speed, 6-speed
Axle/Gears: u/k
Rear Side Markers
Um, I'm kind of a newbie to the lighting on these cars, but what is the purpose of the two rear lights on the farthest corner of the tailights? theyr'e a 194 wedge bulb and they do nothing, as far as i know. Outlined in the picture.
Old Mar 20, 2011 | 09:26 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Rear Side Markers
They do exactly as the title says, they are markers, and required since 1970.
Quoted from Wikipedia
In North America, amber front and red rear sidemarker lamps and retro-reflectors are required. The law initially required lights or retroreflectors on vehicles made after 1 January 1968. This was amended to require lights and retroreflectors on vehicles made after 1 January 1970. These side-facing devices make the vehicle's presence, position and direction of travel clearly visible from oblique angles. The lights are wired so as to illuminate whenever the vehicles' parking and taillamps are on, including when the headlamps are being used. Front amber sidemarkers in North America may or may not be wired so as to flash in sync with the turn signals. Sidemarkers are permitted outside North America, but not required. If installed, they are required to be brighter and visible through a larger horizontal angle than US sidemarkers, they may not flash, and they must be amber at the front and rear unless the rear sidemarker is incorporated into the main rear lamp cluster, in which case it may be red or amber.
Old Mar 24, 2011 | 12:45 AM
Axle/Gears: u/k
So they don't need to work therefore they don't?
Old Mar 24, 2011 | 08:38 AM
jimez1's Avatar
Car: 92 RS
I read it as if installed they are required to work. They are not required outside of Norht America. Canada is in North America, so make sure they light up.
Old Mar 24, 2011 | 09:18 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If yours are not lighting up, then something is "broken". Blown bulbs? Broken wires?
They get power from the tail lights, so if the tail lights light up, that suggests they are getting power & the 194 bulbs are blow (or not in there).
Old Mar 25, 2011 | 12:08 AM
Axle/Gears: u/k
Well i just replaced the bulbs so its gotta be some busted wires somewhere. i'll have to pull it apart and see
Old Apr 15, 2011 | 11:43 PM
Axle/Gears: u/k
Found the problem. Bulbs contacts were dirty. both sides work fine.
Old Apr 17, 2011 | 08:07 AM
jimez1's Avatar
Car: 92 RS
Always look to the e,asiest things first. Bulbs and dirty sockets are much easier than wire chasing. Put some Di-lithium grease in your light sockets. It will help keep the contact, and prevent the corrosin from coming back.
Old Apr 23, 2011 | 09:24 AM
Axle/Gears: u/k
thanks, will do next time i pull the lights apart for an LED conversion
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
