Painting T-top Trim
Car: 1985 Chevrolet Camaro Z28
Painting T-top Trim
Greetings,
I am looking for some advice to refinish the outer trim piece on my t-tops. The black is starting to sun bleach and discolor, turn to a grayish color. If i used a rattle can, would it turn out ok, what color is close to original and would i need to use some type of primer first. Thanks in advance.
Car: 1991 Camaro RS
Engine: 305 TBI
Re: Painting T-top Trim
I used a product called Black Satin. You used to be able to buy it at the parts store. It's in a white can with black lettering and has a photo of a red Fiero on the front.
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
mswen22780
Hello there. I have done a ton of trim work on my camaro and I always use the same method. I will be painting my t roof trim pieces as well as they have some small scratches. First I use steel wool, making sure to scuff the entire area to be painted, then I wash and rinse the area thoroughly with soap and water. After it dries out I mask the piece to be painted and then paint it with a gm trim black or satin black paint. This stuff works really good and makes even my work look pretty professional. I found the biggest thing is making sure your prep is good....I mean lets face it, if the surface is dirty when you paint the paint job is gonna look brutal, but if you take your time and do it right it will look incredible. I am thinking of doing mine today. If I do I will share pictures or at least video.
onthedownlow
onthedownlow
Thanks for the advice. I just find it odd that the center trim piece is perfect, but each T-top is extremely faded.
Engine: 355
alot of times people lean on those strips and with time that can fade them, whereas the center bar has little to no contact with anything looks like new. (:
onthedownlow
onthedownlow
Car: 88' Iroc
Engine: 5.7 liter
Axle/Gears: 2.77 posi
Greetings,
Car: '88 Chevy Camaro. T-Tops.
Engine: 2.8L V-6 (yea, it cruises nice !)
Transmission: 700-R4
Axle/Gears: 3:42's
Nice, I have been looking at doing this myself as well. Thanx!
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
