Airbags/air shocks on a 3rd gen?
Hey, last friday, I was at a car show and I saw an IROC parked, that was almost touching the ground, but when the guy went to leave, his car raised up to around normal height and he drove off...
Does he have airbags or something inside softer springs? I don't really know too much about airbags and such, but I think thats the only way it could have been done..
any ideas?
thanx
any ideas?
thanx
Car: 82 camaro SC
Probably some type of hydro set-up or it's bagged. How fast did it raise up? What sound did it make?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
search the topic you'll find out a lot of info. with our cars not only is it a lot of money,time, and fabrication; but it completely hinders the cars performance.
[This message has been edited by Kandied91z (edited October 23, 2001).]
Yeah, i thought about putting air canisters (higher performance bags) on my IROC, but with the time involved, and the massive performance loss.. i changed my mind
arthur@thirdgenfbody.com
www.thirdgenfbody.com
1985 IROC Resto underway
1992 Trans Am
Aug 9, 2015 04:32 PM
