Blue Halo Headlights on a 82 Z28
Old Jun 8, 2011 | 11:28 PM
Shaz's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 305 TBI
Axle/Gears: 3.08 non-posi
Just for kicks I installed some blue halo headlights on my Z28. The original lights were the factory sealed beam barely-brighter-then-a-candle junk, and my new ones are EXTREMELY bright HIDs with blue halos. It took a bit of rewiring, but nothing more then 15 minutes of work. Personally I think they look great. You'd have to see them in person to do them justice though. My Camaro is black, so a blue halo against a blacked out car = lots of heads turning at night. They've been in for a few hours and I've had 3 different people come up to me and ask about them, were I got them, were they easy to install, etc. I love 'em!
Here's a video of them on YouTube: http://www.youtube.com/watch?v=3pEIhe0u4bI
Old Jun 9, 2011 | 12:36 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Blue Halo Headlights on a 82 Z28
They are nice but becarfull with cops. blue and redlights are illigal in alot of states
Old Jun 9, 2011 | 12:49 AM
crocodile's Avatar
From: the gates of hell, with the camaro parked infront
Car: '85 camaro z28
nice.. how much they run you?
Old Jun 9, 2011 | 08:53 AM
Shaz's Avatar
Engine: 305 TBI
They ran me $100 for all 4 shipped to my doorstep.
Old Jun 9, 2011 | 09:04 AM
mrrman's Avatar
curious...where did you buy them from...not my color though...I went with 6k HID's
Old Jun 9, 2011 | 09:30 AM
Shaz's Avatar
Engine: 305 TBI
I got them on eBay, You can see all that are available here: http://shop.ebay.com/i.html?_nkw=82-...&_sop=12&_sc=1
They come in Blue, Green, and Red.
Old Jun 9, 2011 | 01:02 PM
Cpt Vos Bradley's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: W/C T5
Yeah like someone else said, be carefull with the blue. And be REAL careful with the red. Cops love to get you for "Impersonating an emergency vehicle" out here in California.
That being said... I kinda want some blue halos in mine as well xD
Old Jun 9, 2011 | 03:44 PM
karl's-92'-z28's Avatar
Car: Too many cars
They are only illegal if you get caught....hahahahaha
Old Jun 9, 2011 | 04:05 PM
luvmy64's Avatar
I have red halos on my BMW E36 conversion lights....sooooo....
Old Jul 13, 2011 | 08:33 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Im set. Im doing this. until I feel like doing the e36 conversion
Old Jul 14, 2011 | 10:03 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Those are the same ones I have on my 92. The housings and reflectors are ABS plastic, I've burned out one of the reflectors (driver outside lamp) and had to install a new housing, the other one of the pair isn't far behind, this is with the recommended wattage H4 bulbs.
As soon as I can afford them, I'm changing these Pilots out to a set of non halo H4 & H1 housings by Cibe. Check them out here..
http://www.danielsternlighting.com/
Old Jul 25, 2011 | 01:26 PM
VelocitySc0pez's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 TBI
please help me find install for HID's as i see you have them in your camaro!! i need instructions they will be at my door in a few hours i think
Old Aug 14, 2011 | 12:26 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
same idea but different shape little more expensive to 2/$85
Old Aug 14, 2011 | 12:49 AM
tlamm's Avatar
Car: 91 Firebird
Engine: 5.0 TPI
Transmission: 5-Speed
I personally do not like them becuase they are square. Plus Halos should only be on BMW's. That is it.
Old Aug 14, 2011 | 08:37 AM
Shaz's Avatar
Engine: 305 TBI
I personally love them because they are square. The squareness "fits" the look of the 3rd gen Camaro a lot better then circular halos in my opinion, plus it's something different from the generic circular halo you see on everybody and their brothers car.
Old Aug 14, 2011 | 07:40 PM
V8ReiMeR88MaRo's Avatar
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Those are pretty sweet! I might order the red ones.
Old Aug 20, 2011 | 11:06 AM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Hey for the halo headlights, would you mind showing the light quality as in brightness and how well the light is projected to the ground? I know there not projectors but im curious on seeing how the shines, and if you keep the car like 25 to 30 feet back from a garage door and see how it shines on there? You seem like one of the few with these actual halo lights, so i thought i would ask. Thanks
Old Aug 20, 2011 | 11:54 AM
Al Hasse's Avatar
You're going to burn out the reflectors on those lights. The only glass on them is the lens, the rest is ABS plastic, including the reflector. I have a set and this is how the reflector looks with regular use, this is the better of the two - the other housing had to be replaced because it was so bad. If you look, you can see that it is the recommended wattage bulb (60/55 watt) for the housing.
Old Aug 20, 2011 | 12:19 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I like them might have to get a pair if I dont do the bmw conversion
Old Aug 20, 2011 | 02:38 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
So those are the bulbs that come with the housings and it dulled out the reflectors? Did that company send replacements for the issue?
Old Aug 20, 2011 | 05:05 PM
Al Hasse's Avatar
Mine came without the bulbs, but they are the same wattage as the ones they include now. As I said already, the housings are cheap plastic with a reflective coating and H4 bulbs get HOT. I don't expect replacements and I won't buy another set. If you look closer at the picture, that isn't dulled out, those are black marks where the heat from the bulb burned the reflector. Those lights are coming out as soon as I can afford the Cibe lights I linked earlier from Daniel Stern Lighting.
Old Aug 20, 2011 | 05:48 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
About how long did you have them before all the problems occurred? And is your car a night driver or mostly a day?
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
