New Paint, side moldings removed & Engine Bay Clean Up
Old Jul 8, 2011 | 10:51 AM
RoelSS's Avatar
Car: 86 Trans Am
Axle/Gears: Aussie 9 Bolt with 3.0 Gears
Hey Guys,
I got a new paint job on the Trans Am! Its a 2 Stage Job. I removed the side moldings and I think it looks cleaner. The Body Shop guys broke the worm gear on the pull down motor, so thats why the trunk lid is not fully closed. I bought the worm gear on ebay and replaced and works fine again.
What do you guys think?
Engine Bay Pica are before the paint job. I removed all the AC equipment and cleaned up the engine bay. I re-routed a lot of wires, so all you see is just a nice TPI I need is an AC Delete Box though. I know the hose from the TB to Valve cover is ugly and I am looking for an OEM replacement if anyone has one.
Spark Plug Cables are routed under the headers.
Injector Harness is routed behind the runners.
Coolant reservoir replaced with a small Summit Catch Can
TB coolant By-Passed
New Paint Job
Old Jul 8, 2011 | 08:43 PM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Re: New Paint, side moldings removed & Engine Bay Clean Up
Looks good very good!
I would mask off the engine bay & try to even some of the black.
Old Jul 8, 2011 | 11:32 PM
RoelSS's Avatar
Car: 86 Trans Am
Thanks!
Yeah I'm going to finish the engine bay in black.
Old Jul 9, 2011 | 02:07 AM
karl's-92'-z28's Avatar
Car: Too many cars
Looking good!!!!!
Old Jul 9, 2011 | 03:04 PM
1o80b's Avatar
Originally Posted by RoelSS
Hey Guys,
Engine Bay. I removed all the AC equipment and cleaned up the engine bay. I re-routed a lot of wires, so all you see is just a nice TPI I need is an AC Delete Box though. I know the hose from the TB to Valve cover is ugly and I am looking for an OEM replacement if anyone has one.
Overspray everywhere????
Old Jul 9, 2011 | 03:17 PM
RoelSS's Avatar
Car: 86 Trans Am
The engine bay pics were before the paint job.
Old Jul 9, 2011 | 03:19 PM
RoelSS's Avatar
Car: 86 Trans Am
Originally Posted by karl's-92'-z28
Looking good!!!!!
Thanks!
Old Jul 9, 2011 | 04:30 PM
RoelSS's Avatar
Car: 86 Trans Am
I added the pic after the paint job
Old Jul 9, 2011 | 08:07 PM
aks's Avatar
aks
Car: 92 Z28
Looks awesome! I think firebirds look better without the side moulding on the doors.
Old Jul 9, 2011 | 09:32 PM
lonesomeloser's Avatar
Car: 1983 Z28
Why is your passenger side of the engine lower?
Old Jul 9, 2011 | 10:05 PM
RoelSS's Avatar
Car: 86 Trans Am
Maybe an optical illusion on the angle of the pic? Motor mounts were replaced when we dropped in the engine. Unless one motor mount is higher that the other. Now that you bring that up, I'm going to look in to it.
Old Jul 13, 2011 | 12:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Thank you for the pics of your engine bay,I was considering painting mine black,now that I saw how it will look I'm going to keep mine white.Not that it looks ugly or anything,It's just to dark. I think you did a good job.It's just a matter of preference.
Old Jul 13, 2011 | 01:47 PM
RoelSS's Avatar
Car: 86 Trans Am
You're welcome. I did want to keep it white, but it's really hard to keep it clean, smudge wise. The last pic is after the paint job and they sprayed it all black. The 1st ones were right after we dropped in the engine, so it looks oversprayed as it was mentioned earlier.
Thanks for the input
Old Jul 15, 2011 | 04:14 AM
350tpiirocz's Avatar
Car: 89 Camaro IrocZ
Axle/Gears: 9 Bolt
Right on! It looks clean!!
Old Jul 22, 2011 | 09:48 PM
RoelSS's Avatar
Car: 86 Trans Am
Thanks!
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
sonu1975
Aug 11, 2015 08:38 AM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Aug 5, 2015 11:57 PM
