Cost of paint
Old Aug 8, 2011 | 08:19 PM
protestthehero's Avatar
Cost of paint
Hey guys
Ive about had it with my paint chipping off here and there. I have a 91 z28 thats white. I was wondering what the costs would be for my father and i to paint the car. I have a gun, compressor, and can make a spray booth outta my garage. The real question is what would the cost of supplies for a white paint job. Also id like to paint the car a bit brighter of a white than it already is.
Tyler
Old Aug 8, 2011 | 09:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Cost of paint
Not trying to be a jerk, but none of us (that I know of) sell paint, so to get your best answer, call your local paint supplier, or price it out on the internet - whatever we state might be wrong (prices vary per type, brand, location, etc.).
Old Aug 8, 2011 | 09:41 PM
rfox's Avatar
Re: Cost of paint
White if I remember is the cheapest most of the time. A lot of the $ you will be paying is in the paint and primer you need to know if you want base clear or single stage, along with what primer you will be using. You will need sandpaper and the amount and what grit depends on how far gone the paint is that's on the car and how nice you want it to turn out. Are you going to use sealer? How much bare metal and body filler are you going to have on the car after sanding? There is a lot that goes into it. You can always do the cheap paint job that people have been posting on here using tractor enamel or rustolium or you can use the good stuff. I don't know much about integrity of the cheap stuff but it seems to make people happy.
Old Aug 9, 2011 | 06:49 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Cost of paint
I priced out paint not too long ago and it was around $1100 for the good stuff.
Old Aug 9, 2011 | 08:14 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Cost of paint
Eh? Where are you getting yours from? House of Kolor across the river sells Dupont paint/clear for $30 a quart.
Old Aug 9, 2011 | 08:30 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Cost of paint
Different colors have different prices. Its entirely possible to spend as little as $50 on paint, and in excess of $5000 on paint. It all depends on the amount of body work, materials, and quality of paint you are going to use.
The clear coat UV protectant that covers the exposed carbon fiber roof the ZR1 costs $2000 per gallon.
The question should be how many quarts/gallons will you need to paint an entire car, and much $$$ you have to spend on it.
Old Aug 9, 2011 | 08:43 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Cost of paint
I just called my local supply shop. Autocolor base is $400(gal of sprayable),$25 for reducer and the Autocolor clear is $375(5 liters). UPOL clear is $200 (7.5 liters sprayable). European Passport clear is $200 (7.5 liters sprayable) Seems my recollection of costs was a fuzz off.
Old Aug 9, 2011 | 12:37 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Cost of paint
here is a link:
http://www.paintforcars.com
Old Aug 9, 2011 | 01:31 PM
Re: Cost of paint
Id like to spend bout 500 to 700 buying the paint and supplies in increments. the body (if this helps) is in near perfect condition, no rust no dents no nothing. What would you recommend?
Old Aug 9, 2011 | 01:42 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Cost of paint
I've spent about $1500 in materials on my paint so far that includes all the sand paper as well as the paint, primer etc... Also it's all good stuff dupont.
Old Aug 9, 2011 | 01:44 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Cost of paint
I used PPG Shopline sealer/primer/base and then PPG deltron (better than shopline) clear. Cost me $900 for that plus body filler, sand paper, and random stuff
Old Aug 9, 2011 | 03:55 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Cost of paint
I am under the impression you want to do it right and are willing to spend the money to get there. So since you are doing the prep. and paint yourself you are saving some money.Any way here's what you can expect. I helped allot on this project and learned a few things.
Here's a link to my prep. to paint photos.The price is under the first set of photos. = https://www.thirdgen.org/forums/body...nt-photos.html By the way the photo showing the rear 295/50r15 have been replaced with 255/60r15. Looks allot better to me.
Hotrodboba400
Dec 10, 2019 07:07 PM
birdman_29
Jan 7, 2017 08:24 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
