Got '92 RS 5.0. Want to wash Engine, don't want to damage electronics. Advice???
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I just used wal mart degreeser and a garden hose to clean mine. Didn't exactly do it for me. I didn't use anything powerful for fear of ruining the delicate electronics. Any advice?
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Got '92 RS 5.0. Want to wash Engine, don't want to damage electronics. Advice???
Simple green, used on a dry WARM but not HOT engine. Asst of toothbrushes, and larger brushes. Then rinse. Just cover most of the electronics plastic bags and spot clean them before. Do this a couple of times a week after 3-4 times you should be pretty squeaky.
Protectant helps also. Collinite insulator wax #845 keeps the paint in the engine bay nice and protected through the heat cycles.
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I'm not a fan of using degreaser and what not (just a personal preference) or that shiny stuff that just makes the dirty pretty.
But
Once you get it clean, just take a large sponge or terry cloth and squeeze it over parts of the engine while obviously avoiding soaking electrical connectors. Once everything you want cleaned is soapy, simply squeeze clean water over everything and you're good to go.
I had a 02 Camaro I did this with at every wash and at 100k miles it still looked brand new.
Post 333! Lucky day?!? Maybe I'll find an answer to my relay post ::cross fingers::
But
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I take out the battery, put a plastic bag over the alternator and distributer, hose down the engine bay and the spray it with simple green or purple power dereaser, let it soak for 10-15 minutes, then I take a pressure washer and set it to gentle (still sprays really hard but wont strip paint and break things) and spray away! I try not to spray the elecrtionics and wiring directly but i still spray them gently.
Never had an issue so far, did it all the time on my truck after i went playing in the mud
Car: 1985 IROC-Z
Engine: 355
But
But
Engine: gone
Transmission: gone
Axle/Gears: gone
just cover what electronic you can. distributor and alternator and try not to spray directly on anythign else and you'd be fine. Might even wanna take the distributor cap off after your done and dry it off inside.
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
To protect the wiring/relays etc., go to a dollar store and stock up on some aluminum foil. It's extremely flexible and whatever you cover should stay protected.
theshackle
Mar 5, 2017 06:37 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
