engine bay dress up
Old Oct 29, 2001 | 08:29 PM
brian89transam's Avatar
engine bay dress up
my engine bay looks like the average 100,000mi car. I'm gonna clean everything and get new hood insulation. I might also get a throttle body plate. What else do you guys recomend? Anything to make cleaning easier? Any cool dress up stuff?
Thanks -Brian
89 Trans Am 350: Blue w/ Silver groundfx, rear wing, Eagle Alloy wheels, Grant wheel, Panasonic head unit, Alpine 6x9s, sub, and amps. Custom K&N cold air, MAF screens removed, smog pump & washer fluid tank removed. More to come soon.
Old Oct 29, 2001 | 08:33 PM
lineb's Avatar
Ummm.....maybe colored spark plug wires, painted valve covers, colored convoluted tubing, different billit covers. To clean the engine, i use gunk, then use simple green degreaser in a spray bottle and get all the other little areas. Then spray some tire shine in the engine after your done cleaning it and it will have a nice look.
Chris
-94' firebird formula(I used to have a 91,thats why im on this site)
-Mods: Hypertech programmer 3, ported and polished MAF sensor.
-Future Mods: cat-back exhaust, slp intake, pullies.
Old Oct 29, 2001 | 08:46 PM
un4givin89's Avatar
Hey man, well I tell ya somethign that works great, that Black Magic Wet tire stuff on the hoses makes them look brand new man.
I'd like to get some new hood matt fire stuff to, whatever its called.
un4givin89
Old Oct 30, 2001 | 03:31 PM
I saw a throttle cable cover that would look nice on my car, but they don't make one for it. I'm not sure if I like billet and chrome, maybe just black and aluminum. I want to try and make it look simpler. Tpi engine bays usually look pretty cluttered. I'm planning on getting a strut brace too, that will make a cool difference in looks.
Old Oct 30, 2001 | 07:19 PM
cvpde37's Avatar
Another excuse to post an engine pic.
Just take off all of the little things you can and clean them up, use black magic or a similar product on the hoses and don't be afraid to get things a little wet. A friend of mine uses scrubbing bubbles (a bathroom cleaning product) sprays it on and lets it set for a while and then sprays it off. Seems to work pretty well.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Oct 30, 2001 | 07:31 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Autozone has a radiator overflow kit that will fit under the front bumper/radiator cover in front of the a/c condensor.It'll clean up the inner fender area. I also pulled out every wire and every connector/sensor that I didn't need when I put my new motor in and wrapped what I did need in new wire loom.I used throttle body/intake cleaner to clean all the gunk.It seemed to worked better than engine degreaser.I repainted the steering box,brake booster,and sway bars,cowl,headlight trim bezels,and whatever else I could while I was in there.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Carter 750 carb,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers and open air cleaner,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-piller pods,180* thermostat.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Oct 30, 2001 | 08:16 PM
White_Boii's Avatar
cvpde37 i hope thats your engine bay, if so, where did you get that radiator hose? i want one so bad and cant find a real one to save my life!! if anyone else knows, please help me out!
Old Oct 30, 2001 | 08:53 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
coat all you hoses with tire gloss, and take 409 grease cutter or simple green to everything else. One other thing i did, was take just about everything i possibly could out of the engine bay and i painted the inner fenders satin black, along with the battery tray area, and vaccuum can area. While it doesn't look as good as some of these peoples engines, it definately cleaned things up.
Eric
My 1986 Z2814.59@95.6
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles! no times yet, just got it to start.
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Moderator at: www.generation-3.com
Old Oct 30, 2001 | 09:01 PM
cvpde37's Avatar
White, yes that is my engine bay. I bought the upper and lower hoses from Summit for around $80. They dress things up a bit and are very functional.
1984 Z28 350
My Web Page
Old Oct 30, 2001 | 09:05 PM
White_Boii's Avatar
great! i saw those, but i didnt know if they were real, you know, like they have the immatation braded bull...but this stuff is true?
Old Oct 31, 2001 | 12:47 AM
Roshambo's Avatar
When I swapped to the Vette heads, I pulled all my emissions stuff (I live in Southern Oregon where we have no testing at all.) I cleaned everything with Simple green and regular red auto rags, the hoses I put Eagle One Tire Wet on. The Tire wet does a great job of keeping the hoses glossy and the simple green cuts through the grease and road grime that builds up on the motor.
The motor had 102k miles on it, and I had just installed a STB and K&N in the before picture.
BEFORE
DURING
AFTER
-Roshambo
-Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, No Cat, 3" exhaust from Y-pipe back, MSD Super Coil, Accel 8mm wires, L98 Aluminum Heads, Ported and Polished Plenum, Siamesed Intake, Aluminum Driveshaft, Edelbrock 3 point Strut Tower Brace
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
