zo6 wheels 19 by 11 pics. please
Old Sep 29, 2011 | 06:32 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
just got a real good deal tire rack for some 19 by 11 z o 6 wheels for 28 dollars a piece .
I may go with the 18 by 8. in the front .just wanted to see if anybody has any pictures of a staggered firebird like that .thanks
Old Sep 29, 2011 | 06:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: zo6 wheels 19 by 11 pics. please
28 bux? are they for a model zo6?
Old Sep 29, 2011 | 06:51 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
Yes 2000 vett. They still have them but only rears
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i just did a quick search on tirerack and didnt find anything for $28. stock z06 is 19x10 up front and 20x12.5 out back.
the wheels that have for stock z06 are over a grand each...
Old Sep 29, 2011 | 06:54 PM
travis401's Avatar
Car: 91 Camaro RS
found the ones you were talking about, theyre not z06 wheels, theyre c6 wheels made by sport edition. theyre on close out for $29 each...not bad.
according to the specs, they require a 285 tire, which youre not gonna fit that under a stock 3rd gen without major rubbing issues. about the widest you can go up front is a 245, maybe 250.
Old Sep 29, 2011 | 07:00 PM
Zombie_Reaper's Avatar
Car: 1982 Z28 Camaro
Engine: 305 soon to be 383
Transmission: TH350
Axle/Gears: 10 bolt unknown gear
Yeah I thought he was pulling our leg, but for c6 wheels not bad.
http://www.tirerack.com/wheels/resul...00&autoModClar=
Also, the sport additions Z06 don't look bad either for $29 each. With shipping to my door it would be $140.
Old Sep 29, 2011 | 07:13 PM
travis401's Avatar
Car: 91 Camaro RS
tempted to buy a set then throw them on cl for double....
Old Sep 29, 2011 | 07:34 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
There are people I know of that run 275s up front with the proper offset wheels, but with 9" wide wheels, not 11" wide!
Old Sep 29, 2011 | 07:37 PM
travis401's Avatar
Car: 91 Camaro RS
doubtful the c6s have enough offset to run a 285 tire upfront.
Old Sep 29, 2011 | 07:38 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I run 275s up front and friend runs 315s on rear
Old Sep 29, 2011 | 07:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
28lbs of Chinese cast tinfoil? no thanks, not even for 28bux....tempting as it may be to flip them....
Old Sep 29, 2011 | 07:42 PM
travis401's Avatar
Car: 91 Camaro RS
but do you use wheels with a 79mm offset and a 9.09" backspacing? if not then its moot point on what you run.
Old Sep 29, 2011 | 07:48 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
nobody is saying those wheels with their offset and width will fit in the front. Even with spacers, i don't see an 11" wide wheel fitting in the front without looking silly. I'm just saying that it isn't actually the tire width that would cause the fitment issue incase someone reads this thread and gets the impression that you can't fit a tire wider than 245 under any circumstance.
Old Sep 29, 2011 | 07:52 PM
travis401's Avatar
Car: 91 Camaro RS
on stock rims, 245 is about the limit. aftermarket with different offsets and such, yea you can go wider.
Old Sep 29, 2011 | 07:56 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
The z06 sound good only shipping is way more then the wheels.
Old Sep 29, 2011 | 08:17 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
I only got two se zo6 11s for the bacK. I know i cant run that up front. I was thinking of 18 x 8.5 up front . I have 17x9s on it now w/245s up front an 275s in back. I already have some good 295 30 19 tires
Old Sep 29, 2011 | 08:46 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Many of us are running 275s without rubbing issues, even very lowered.
Old Sep 29, 2011 | 08:51 PM
travis401's Avatar
Car: 91 Camaro RS
on stock rims?
Old Sep 29, 2011 | 08:57 PM
Car: GTA
Since there is no 275R16 or a stock 17" (except maybe the Firehawk wheels, but what size did those come with?) 3rd gen wheel, no.
But I have seen several people run stock Vette wheels w/adapters & 275s.
Old Sep 29, 2011 | 09:02 PM
travis401's Avatar
Car: 91 Camaro RS
see, thats the key word, adapters. with a stock wheel, or some wheel generally close to stock offset, youre not gonna fit much larger than that.
Old Sep 29, 2011 | 09:25 PM
Car: GTA
Define "stock". As I said already, there is no 275R16 nor were 3rd gens stock with 17s, besides the Firehawk. But that also means that yes, there was a stock 3rd gen with a 275 front tire. Ronal 17x9.5" aluminum wheels equipped with the trademark Firehawk SZ P275/40ZR17 tires. And my aftermarket 17x9 wheels & 275s fit up front with no adapter. Not stock, but also no adapters.
I just didn't want anyone reading your statement of "about the widest you can go up front is a 245, maybe 250.", which is obviously not true.
Old Oct 5, 2011 | 11:26 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Got mine. I'll post pics when I get them on. Just the back right now. Then I will order fronts with a different offset later. If I don't like the looks, at the price I can surely make my money back.
Attached Thumbnails zo6 wheels 19 by 11 pics. please-split.jpg   zo6 wheels 19 by 11 pics. please-splitt1.jpg
Old Oct 7, 2011 | 01:05 AM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
what size are you going to run for .the front 18s? I still want to use the 19s I have .
Old Oct 12, 2011 | 04:11 PM
Engine: 2002 SS LS1
Okay, I realize I need rubber, just doing measurements and making sure this is the route I want to go. I have a 4th gen 2002 SS Camaro rear end and it does not require spacers for the 4th gen wheels I have or the C6 rims I am comparing.
Give me constructive criticism and not, "oh them is too dang wide" junk. Tell me what you think over all and if I am overlooking something.
Rim comparison
I have a fourth gen rear end and the back of my car is basically the same as a fourth gen. With the 2002 rear end I do NOT need spacers for fourth gen rims. Here are my 2002 SS split spoke rims, 17x9.
Here is the 2009 C6 Z06 19x11 knock offs I bought with a 64mm offset. NO spacer needed.
Distance from the bulge on the body of the wheel well on the C6 rim
Distance from the SS rims
SS rim front looking back
Old Oct 12, 2011 | 04:12 PM
Engine: 2002 SS LS1
C6 rims front looking back
C6 rim looking down front the wheel well bulge, only come out a 1/2 inch compared to the SS rims due to the offset
SS rim looking down from wheel well bulge
Everything clears on the bottom
After the tire is on I will probably need to do the big hammer mod, but the rim clears quite well.
Old Oct 12, 2011 | 04:21 PM
Car: GTA
315s will drop on almost like factory with only slight BFH modding needed. 335s will work too with only a a little more BFH. Mostly depends on how low you go.
Old Oct 12, 2011 | 04:50 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
That looks Damn nice man.
When its all said and done, what will you have done to make those rims fit on the car? Spacers etc?
Also, i'll take those SS rims off your hands when your done. Thanks. :P
Old Nov 2, 2011 | 05:13 PM
Engine: 2002 SS LS1
its funny, bought those rims from tire rack and found an even better deal on C6 Z06 rims, BFH'ing today and tomorrow and will post pics. I am going to just sell the TIRERACK rims for what I bought them for when ever I can.
Old Nov 2, 2011 | 10:39 PM
karl's-92'-z28's Avatar
Car: Too many cars
How much?
Old Nov 3, 2011 | 07:43 PM
4FishLimit's Avatar
Car: 1986 Trans Am
Engine: LB9
Transmission: TH700R4
Axle/Gears: 2.73 & LSD
Dude, thanks for the heads up. I just picked up a pair...can't wait to get them on my T/A when my engine and drivetrain project gets finished up next spring!
Old Nov 12, 2011 | 06:46 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
I had a set of oem Rims just like those but in the silver color they come in. i didnt like them but i got them for 150 from some lady by where i live. garage sells are the best. sold them for 400 later just because i needed cash asap.
Old Nov 17, 2011 | 01:51 PM
Engine: 2002 SS LS1
19x11 79mm offset 20mm spacers (which will come off later) 325/30/19 and
19x9.5 57 mm offset 2inch spacers 275/30/19
Old Nov 17, 2011 | 04:14 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
very nice. I've been looking at those wheels I'm just ot a fan of the rivets.
Old Nov 18, 2011 | 10:41 PM
travis401's Avatar
Car: 91 Camaro RS
you have to do any sort of tub to fit the 325's out back?
Old Nov 20, 2011 | 01:59 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I think those wheels look outstanding on YOUR car! The fact that youve gone with large rotors and upgraded brakes makes a HUGE difference in the overall appearance of the wheel. I think if someone has stock brakes they might not look so good.
Lanz06
Mar 13, 2019 06:07 PM
drptop70ss
Oct 4, 2015 09:44 PM
Breazlan
Sep 25, 2015 11:20 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
