Throttle Body boot
Old Oct 18, 2011 | 09:53 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
Throttle Body boot
I would like to replace the black boot that goes fromt he intake to the throttle body (TPI) with aluminum.
But I am being told that the torque will crack the plastic intake.
has anyone done this, and can that happen
Old Oct 18, 2011 | 10:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Throttle Body boot
As long as your motor mounts aren't shot (ragged out rubber stock) and you use flexible couplers, there shouldn't be any real issue.
Old Oct 31, 2011 | 02:59 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
agreed - there's gotta be some flex somewhere since the motor and car do not shake/vibrate the same. rubber or silicone couplers should be enough to do the job though
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
