Tips on engine repaint/clean up?
Old Dec 27, 2011 | 01:33 AM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
My 1992 Camaro RS has a completely stock 305 TBI engine that runs beautifully. But while running flawlessly, it needs a little bit of a clean up. The black engine paint is coming off of the engine block, intake manifold, and valve covers. But, there is also a lot of dirt and dust sticking to the components of the engine. Anyone have any good tips to repainting and cleaning up my engine to make it close to car show material without completely tearing it apart? I'll put some pictures of the engine on here, tell me what you think are some good ideas to make it look good. Thanks
Attached Thumbnails Tips on engine repaint/clean up?-img_2108.jpg   Tips on engine repaint/clean up?-img_2112.jpg
Old Dec 27, 2011 | 03:18 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
Re: Tips on engine repaint/clean up?
Jake use the search function on the red toolbar at the top for a ton of detailing ideas. When I did mine I unbolted and removed everything I could from the intake and front of the engine. Have a set of Torx sockets handy for the accessory brackets and take pics as you go for reference. I used simple green to clean everything. Take your time masking and spraying as this can make or break the job. Aluminum foil works great for masking hoses and wiring.
Personally I avoid gloss black paint under the hood for two reasons: 1) Most parts were satin black from the factory. 2) Gloss black will show every speck of dust.
Old Dec 27, 2011 | 07:05 PM
one92rs's Avatar
Car: SOLD!!!!!
if you dont want to take it all apart then take it to the car wash and use the tire cleaner (greenstuff) and spray the engine down with it. liberally. let it sit for about 5 minutes and then rinse it off. do not put the sprayer close. keep it about a foot away and clean her off. then go to the auto parts and buy the can of stuff called spray engine detailer.
Old Dec 27, 2011 | 09:07 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
in the past I cover up all electric stuff with some shop towels. The I soak it down with wd-40 let site for 5 to 10 min then wipe it off. Its works great.
rocn7roc
Sep 21, 2021 02:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
tecustomz
Aug 16, 2015 02:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
