How to clean the hood louvers on an Iroc
Old Apr 25, 2012 | 05:26 PM
TVIROCZ's Avatar
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
I am just curious if there is anything I can buy or a method to use to really clean up my hood louvers. I would like to make them look new again. I tried soap and water and that doesnt work. Any suggestions?
Old Apr 25, 2012 | 10:22 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Axle/Gears: G92
Re: How to clean the hood louvers on an Iroc
I use this stuff on all of my vehicles. Just make sure it isn't going to get wet (i.e. rain) for the next day or two.
A small rag and Q-tips will be needed to get the louvers done.
http://www.mothers.com/02_products/06108.html
Old Apr 26, 2012 | 09:21 AM
TVIROCZ's Avatar
Thanks, hopefully it takes off the oxidation.
Old Apr 26, 2012 | 10:46 AM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I also used a similar product on the louvers. I also apply a coat of wax every once and a while this seems to darken them up a little.
Old Apr 26, 2012 | 08:31 PM
87rocred's Avatar
Car: 1987 IROC Z
Baby oil works wonders on dash too
Old Apr 27, 2012 | 12:16 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
What ever you do don't break 'em. Replacements are like a hunnert bucks a piece.
Old Apr 27, 2012 | 07:54 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I'm currently refinishing a set of louvers. Took me almost 3 months to find a set that's worth putting on my car. Yes, EXPENSIVE.
They're in primer now and I'll be blasting them with some of the SEM trim paint.
A little epoxy, filler, and sanding is going a long way.
Old Apr 27, 2012 | 09:51 AM
sc@hms's Avatar
Car: pickup
I've had good results with Turtle Wax ICE in theliquid form. It makes them black but not real shiny or greasy looking. Plus it doesn't matter if you get it on the paint. Just wipe off any smudges with a microfiber.
Old Apr 27, 2012 | 09:53 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
The ICE is good stuff. Doesn't last as long as I'd like it to though.
Old Apr 27, 2012 | 07:10 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Try Chemical Guys Fade to Black or Back to black, unlike the parts store products they will not harm the plastic by drying it out. If you look at the trim on my Durango windshield you will see how black this product changed it; it is water based and lasts about a month if you wash the car every week. The can goes a long way and the stuff works great, once its on for a half hour I buff it with a micro fiber towel to clean off any residue.
Attached Thumbnails How to clean the hood louvers on an Iroc-trim.jpg   How to clean the hood louvers on an Iroc-chemical-guys.jpg
Old May 11, 2012 | 08:21 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
For the dashbaord and other interior trim try 1Z Einszett Cockpit Premium or Sonax Dashboard Matte Cleaner.
For the rubber seals use nothing but 303 Aerospace Protectant.
On the louvers use some very fine cut polish to get out the blemishes and smooth the finish out. Then use a wax as a sealant. Be careful with the plastic, you don't want to rub too hard and melt or burn the palstic.
You can find just about anything you need for car care at http://www.autogeek.net/
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
