powdercoat basics
Old Jun 16, 2012 | 10:53 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
powdercoat basics
What can and cannot be coated?
I want to powdercoat my water pump and such, but don't know if it would **** it up. Can i partially disassemble the waterpump to coat it?
Old Jun 16, 2012 | 11:09 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: powdercoat basics
why would you want to waste 80-100$ on powder coating a part that usually needs replacing?
People usually powder coat things that they new will keep or wont fail.. like an intake manifold or sway bars ect.
Well once they spray on the powder, they bake it in an industrial oven at 300-350* so if the bearings can withstand that heat, then you should be ok.. Just make sure you cover or plug any threaded hole.
Old Jun 16, 2012 | 11:11 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Just paint it or buy one that is powdercoated. Besides bare metal would cool better than powdercoat correct?
Old Jun 16, 2012 | 11:12 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
my current one is rusty as all hell. I dont like rust. at all... and water pumps are not replaced all that often so its not like its not a complete waste.
Old Jun 22, 2012 | 10:06 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
do I absolutely have to sand blast something before I powdercoat it?
Old Jun 23, 2012 | 03:30 AM
karl's-92'-z28's Avatar
Car: Too many cars
Just paint it instead
Old Jun 23, 2012 | 04:38 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
i mean for other stuff like cylinder heads
Old Jun 23, 2012 | 05:37 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you want to powdercoat cylinder heads ??? never heard of it being done . but , lots of things i have never heard of . good luck .
Old Jun 23, 2012 | 05:49 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
just the cast iron stock ones so they look pretty and I can sell them for more :P
Old Jun 23, 2012 | 08:10 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I don't believe powdercoating would hold up to the extreme temperatures of cylinder heads, but I could be wrong.
Old Jun 23, 2012 | 08:15 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Parts need to be cleaned (sand blast is the best way) before they can be powdercoated.
Try spray engine enamel instead.
Old Jun 23, 2012 | 08:25 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I've seen powdercoated engines...
Old Jun 24, 2012 | 03:22 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
The cleaner the part the better... blast away! The gun is a positive charge and the peace your working on is negative the particles cling to it but you also have to make sure you wash them good get off all the contaminants and blasting residue and if you really want to get some good adhesion then chemically etch but for most home hobbyist just a good blast, wash and coat is all you need... If your doing the coating your self who gives a crap what your coating as long as you use common sense like taping off bearing races and plunging threaded ends etc... and as far as heads and engines go with powder coating, powder coating in general mostly consist of using plastic powders... looks good for awhile but doesn't seem to last and iv never heard of anyone doing a true ceramic coating to a block since the amount of heat needed would most likely cause distortion...
Old Jun 24, 2012 | 01:18 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I read somewhere that over time it just looks better because of how hot the engine gets.
Old Jun 24, 2012 | 01:33 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Yes you can powder coat a water pump. Yes you can powdercoat heads and engine block. Been there done that. Esp. motorcycle stuff. Cylinder jugs , case, trannys, etc..
InfernalVortex
Apr 20, 2021 11:31 AM
loud91rs
Oct 5, 2015 10:05 PM
hartsmike
Oct 2, 2015 07:11 AM
Luigytico09
Oct 1, 2015 08:46 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
