What do you guys use on water spots?
Old Jun 29, 2012 | 01:11 AM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I have water spots all over my windshield and t-tops. I've used Nu-glass from Duragloss applied with a buffer, and while it is an improvement, it does not completely eliminate them. It seems nobody has a sure fire solution, and the water spots really make the glass look like crap.
Old Jun 29, 2012 | 01:18 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: What do you guys use on water spots?
I dont usually have problems but if they're bad I use a SOS pad with windex
Old Jun 29, 2012 | 05:38 AM
Damon23's Avatar
Car: 1992 Z28
Transmission: 5 speed
Mothers makes a product for that now but ant metal polish should do the trick.
Old Jun 29, 2012 | 01:56 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I have always used fine steel wool and some window cleaner then cleaned them again. If your tops are Lexan DO NOT use the steel wool on them-glass only. Make sure not to rub too hard or hit the trim, but give it a shot and you should like the out come.
Old Jun 29, 2012 | 03:04 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Probably need to try vinegar or some kind of diluted solution that removes hard water deposits. Anything you try would need to be done in an inconspicuous place so you don't do any permanent damage.
Edit: This might explain it a little better than I can:> Link
Old Jul 1, 2012 | 04:03 PM
84z28BlueDevil's Avatar
Car: 84 z28/ 79 trans am
Engine: 305 LG4/pontiac 301
Transmission: T-5/th350
Axle/Gears: 4.10s/3.42s
um...ive used just windex and paper towels lol
nuggie
Aug 25, 2015 01:27 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
