Fitting new gauges to stock look?
Old Aug 7, 2012 | 04:01 AM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
I'm doing an engine swap here with an old 69 Pontaic 400 motor. My main thing with this project is to make it look like it came from the factory like this....and I personally HATE the look of aftermarket gauges. I want to make all 6 gauges work like they should.....would it be possible to take the recieving part of the "new" gauges and swap the old needles and faceplate over them? Or atleast the needles, I could have a custom, original looking faceplate made up. Anyone do this before?
Old Aug 7, 2012 | 05:19 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Fitting new gauges to stock look?
I know it's possible - I see it in magazines from time to time.
You can check out Speedhut.com All of their gauges can be 100% custom designed. They have an extensive custom process on their website but you can call them and get things changed even more so. There are at least 2 threads on TGO about them and all have had nothing but amazing things to say about them.
A new set of gauges are on the very top of my want-to-do list which includes a GPS speedo from them along with a Tach / Oil PSI custom gauge as well.
Edit: At one point I sent them an email and they said if I wanted to do exact look alikes all I had to do was send them a photo of the stock gauge that I was wanting to replace and they would make the new gauge to look EXACTLY stock for a messily $10 more.
Old Aug 11, 2012 | 04:15 AM
Ok, well I bought and tore apart an Equus brand water temp gauge as an experiment, and they look SUPER similar. What are the chances of my original gauges using the same reference voltages as the after market ones?
Old Aug 11, 2012 | 06:54 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
so you want aftermarket gauges that look and work like your stock gauges... why not just use the factory gauges?
Old Aug 11, 2012 | 02:31 PM
The gauges are ECM controlled aren't they? Or can I just use the sensors that come in an aftermarket kit and wire them up accordingly, or are the voltage signals different between the stock gauges and aftermarket ones?
My question is, overall, do I need to replace the receiving end of the gauge to make them work with my old 60's engine?
Old Aug 11, 2012 | 05:36 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
https://www.thirdgen.org/forums/afte...order-led.html
Old Aug 11, 2012 | 11:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Just put the stock senders on your engine.
Old Aug 11, 2012 | 11:52 PM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
No, not at all. I just finished pulling the last of the ECM wiring harness out of my carb converted 85 Bird. All the gauges still work. Use your stock gauges and as said above, just transplant your 1992 senders to the 1960's engine.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
R3500
Aug 17, 2015 12:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
