My 1985 Z28 Camaro Build
Old Dec 26, 2012 | 07:46 PM
StripedZ28's Avatar
Car: 1985 Z28 Camaro
Engine: 390CI SBC Stroker
Axle/Gears: 4.10 (Ford 9")
Hi guys! Ive been a long time visitor but since my build is finally coming along I figured i should join the community. I wish i would of joined sooner! But anyway here are a some pictures showing the progress of my build.
Pulling the old and tired LB9 out.
Tearing the body apart for the repaint.
Straightening out the door dings.
Spraying the primer surfacer.
Got the all the jams and engine bay sprayed.
Getting the new Stinger Fiberglass front bumper cover mounted and lined up.
After I finished doing the antenna delete and finished all the prep work it was ready to be sprayed.
Ill post the pictures of it getting sprayed a little later.
Old Dec 26, 2012 | 08:38 PM
LivinLarge's Avatar
Re: My 1985 Z28 Camaro Build
Progress looks great! What wheels are on it?
Old Dec 28, 2012 | 06:06 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Looks real nice, can't wait to see it completed. The antenna delete is a nice touch.
Old Dec 29, 2012 | 09:07 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Coming along nicely! Love the wheels.
Old Dec 30, 2012 | 12:30 AM
StripedZ28's Avatar
Thanks guys! I think I maybe should of put this in the Members Camaros Section but I though id wait till the car was somewhat done till I start a thread for it there. The wheels are actually Bullit Replicas. Idk why but I just love those wheels and for some reason I think they really complement the car too. But I always thought the car sat too high though. You cant tell from these pictures since the car is completely stripped out. I want atleast IROC height so ill probably end up getting the Eibach Pro Kit.
But yea the big antenna always bugged me and you really don't need em with mini amplified antennas you can mount hidden.
Here are some pictures of it getting sprayed.
I sprayed the car with sealer then sprayed the white in the center sections for the stripes. After that flashed off dry the hood was mounted on the car for masking the stripes so I could be sure the stripes would line up from the front end to the hood. It was very tedious to get perfect.
After I got done masking the stripes and re cleaned and tacked the surface I sprayed the base. For costing 376 dollars a quart it sure could of covered better .
After that I let the paint flash dry to the touch and pulled off all the stripe masking. Then I just had to tack the car and spray the clear! I took these pics after 1 coat of clear.
After I got 3 heavy coats of clear on I let it bake for 40 Minutes at 140 degrees and let it sit overnight. The next day I rolled it out of booth and took a couple pictures.
Im probably gonna end up cutting the whole car and re clearing it for that ultimate show car depth of gloss. Still got to paint the ground effects,door handles, fuel door, and stuff like that. Got some plans for the interior too.
Ill post info on the engine build a little later too. Let me know what you guys think! Thanks
Old Dec 30, 2012 | 01:16 AM
Engine: 355
Wow the paint looks amazing! Such a nice deep red color. Man your car is gonna look killer when it's done, awesome job.
Old Dec 30, 2012 | 04:59 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Very very nice!
Old Dec 30, 2012 | 08:07 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Great looking paint!
Old Jan 2, 2013 | 02:18 PM
ELINDEN's Avatar
Sweet!!!
Old Jan 2, 2013 | 09:08 PM
StripedZ28's Avatar
Thanks for the kind words guys! Means alot! IF anyone wants to know the exact colors let me know. Ive been thinking im going to go with an emblem delete for this car. I think with the stripes the the emblems on the nose and rear bumper will look out of place. I also think these cars look cleaner without the side skirt emblems deleted. What do you guys think?
Old Jan 2, 2013 | 10:05 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I usually don't like stripes but those look killer! also what's that called with the pins in the door? Can big dents be taken out like that?
Old Jan 2, 2013 | 10:30 PM
StripedZ28's Avatar
Thanks! And its called a stud welder dent pulling system. The stud welder itself is sometimes called a spitznagel. Google it for more info. You can remove pretty big dents with it if you know where to weld the studs and what sequence to pull on them. Just gotta be careful so you don't pull the stud off the door and leave a small hole. Works very well.
Old Jan 3, 2013 | 11:05 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Very nice job! Small problem, though... the stripe on the left side of the hood doesn't line-up with the stripe on the fascia.
Old Jan 3, 2013 | 04:34 PM
StripedZ28's Avatar
Good eye! The hood wasn't lined up completely in those pictures so when spent some time lining the hood up its less noticeable. But its still not quite perfect. I don't get how it happened. I might end up re doing the stripes on the hood . No opinions on the emblem deletes?
Old Jan 4, 2013 | 07:57 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Looking good man-I love the wheels, but wish they had some dish to them at least in the rear. Over all the car is coming along nice. I am a huge fan of bright red cars.
Old Jan 5, 2013 | 10:27 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Nice car, I hate stripes on these cars, but the quality of work on your car is undeniable. That red just screams with the white of the stripes to set it off. Great job.
Old Jan 5, 2013 | 12:21 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
IMHO--
Delete the bumper cover badge..
Old Jan 5, 2013 | 01:22 PM
DethVenture's Avatar
Car: 1992 Camaro RS
Engine: L03 5.0L
Transmission: 700R4 Auto
Wow, that paint is KILLER! Love the stripes.
I say keep the emblems. The front emblem will fit nicely in between the stripes, but the Chevrolet logo should be kept off the grille. It would overlap the stripes.
Also, do you plan to paint the headlight buckets black?
Old Jan 8, 2013 | 02:12 PM
StripedZ28's Avatar
Originally Posted by t-top havoc
IMHO--
I really should of made this decision before painting but oh well, I had to much other stuff on my mind. You think both the front camaro badge and the rear bumper z28 badge? thanks
Old Jan 8, 2013 | 02:17 PM
StripedZ28's Avatar
Yes im going to bead blast the headlight buckets and the springs that hold the buckets in and spray them gloss black. As far as headlights im eventually going to do a FX-R HID retrofit. And for the grill I think im going to make a custom one that just covers the holes on both sides of the license plate spot.
Old Jan 8, 2013 | 02:24 PM
StripedZ28's Avatar
Thanks! Yea I wanted a little dish in the rears too but it wasn't and option with these wheels.
Thanks! Hopefully this car will change your mind about stripes
Old Jan 8, 2013 | 03:25 PM
1ACindy's Avatar
great paint color!! the car looks stunning!
Old Jan 21, 2013 | 10:40 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Any up dates on this build? Trying to see how that fiberglass front turned out. Pictures # 5 show ground effect area of bumper sticking out from fenders. How was this resolved?
Old Jan 24, 2013 | 03:33 PM
StripedZ28's Avatar
Hey guys! No real significant updates since Ive been real busy working on repainting an old Fastback Mustang to make some $$$.
But the ground effects were not fastened on to the fenders yet in that picture, that is why they were sticking out.
Thanks again for the compliments guys.
Old Jan 24, 2013 | 05:00 PM
Benc1's Avatar
Would love to see pictures of the front complete when you have time.
Old Aug 11, 2014 | 04:00 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
I am going to bring this back form the dead lol. How was the fit and finish of the front end? I am looking to swap to a more sturdy front end without all the weight and I am not really looking to go full 1 piece front end. I need something to withstand 180+MPH and not worry about running it over.
Old Aug 24, 2014 | 07:57 PM
StripedZ28's Avatar
I really have all positive things to say about the front end. It didn't need any body work, it comes with a nice thick primer surface to block and DA out. Its very sturdy, I can push the car onto the trailer with front end. It would very simple to add bracing with a little fiberglass if you thought it needed it, and it wouldn't add hardly any weight. It is a bit difficult to put on due to how rigid it is but not too bad. Overall highly recommended.
Old Apr 25, 2016 | 09:44 AM
propaintball96's Avatar
In the fifth picture below, why is the end of the bottom spoiler hanging off the fender?
Old Apr 25, 2016 | 11:33 AM
StripedZ28's Avatar
Just to clarify to everyone wondering why the Stinger front ends spoilers are not sitting tight against the fender. I left the brackets off so there was a gap I could spray paint in between the fender and fiberglass spoiler. Once the brackets are on it sits tight against the fender and looks factory. I highly recommend the Stinger Fiberglass front end to everyone.
Old Sep 19, 2019 | 12:13 PM
Sonoma92's Avatar
Do you have any pictures of how you mounted the fiberglass bumper?
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Reddeath210
Oct 6, 2015 08:20 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
