Whats Your Winter Project
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Well as we move into November its that time of year again to start thinking about upgrades and winter projects. SO just curious as to what everyone had planned.
Car: 87 Z/28
Engine: 5.0L
Axle/Gears: 9 Bolt posi
Re: Whats Your Winter Project
sofar the plan is:
-finish up the garage
-strip the Z-28 down to the shell
-cut and patch rust spots
-prep for paint
-finish the LB9 carb'd build
-hopefully start re-assembling
also have to put a ski rack on the caddy after I get back from work
-prep for paint
Car: 91 formula
Engine: 350 tuned port. bolt ons
mild porting of my tpi along with slp runner porting. And some suspension mods to get rid of the gm stamp steel stuff.
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
Gonna finish my project that was started almost 3 years ago. Got it on the road this spring but this winter its getting; subframe connectors, all rubber suspension components replaced with poly, shocks and struts, paint, and maby a new engine.
Car: 1986 IROC-Z
Axle/Gears: 4:10
I'm redoing the floors in my house. Looks like there was water damage at some point in the past so this turned into a bigger project than i thought. I'll continue saving money this year and next year I hope to start a new project.
s10 xtreme with a cammed and stalled ls 5.3 swap. Should be fun!
Car: 89 Iroc
Engine: 305TPI
3800 Series II w/ turbo, new 5 speed, SFC, PHB relo brackets, Koni shocks, and maybe carputer.
Ah ****, you said winter project. That is probably going to take me 40 years.
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
91 GTA-paint front and rear fascias.
88 GTA-Wet sand and buff.
I can't find the time to do anything else...
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Wheels and tires. Possibly lowering springs if funds permit.
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
PULL ENGINE FRESHENING UP NEW ROD & MAIN BEARINGS OIL PUMP AND GASKETS
OR MAY-BEE JUST REBUILD MY 0LD -377 MAKE IT A 383 MONEY WILL DECIDE
STRIP HOOD NOSE OF CAR REPAINT
RELOCATE BATTERY TO REAR
PUT CAR ON A DIET FRONT AND REAR INNER BUMPER DELETE DOOR BARS GONE ANYTHING ELSE I CAN CUT OUT AND THROUGH AWAY
R&R ALL OILS
MOST IMPORTANT !! SERVICE AIR FRESHENER MY DRAG SLICKS!!!
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Windows,Roof,siding,Pourch
then id like to start thinking about buying my 2001 white trans am ws6!!! maybe complete steering rebuild on the iroc-z
then id like to start thinking about buying my 2001 white trans am ws6!!! maybe complete steering rebuild on the iroc-z Senior Member
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
-Prep for paint
-Paint on the 25th of November
-Sound system upgrade
-Get my new interior finally put in
-New exhaust (maybe)
-Add a few little trinkets (shorter shifter, new shifter ball, a-pillar gauge pod, LED's for the digital dash)
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
I bought a 97 Z28 with a very nice 383 LT1 6spd last month, my winter plans are to find a nice 85-87 SC camaro to transplant the entire drivetrain into. I hope it'll be a fun sleeper.
-buy a crane cam, install it late winter, put motor in sometime early spring.
-gonna try to do the 4th gen washer fluid and overflow tank swap
-gonna try to port/polish intake manifold, maybe the new summit aluminum heads
-clean up my 2 sets of cast iron heads to sell them
-try to clean up the engine bay a little, or atleast come up with a plan to clean it when the motor goes in
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
glow gauges for the dash humount for the head unit mod the console top to get two led cup holders installed
lower car 2" prep car for my buddy to spray paint
Car: 1991 Trans am
Engine: 350 tpi started 6.0 ls swap
Axle/Gears: 2.73 soon to be 4.11
My winter project is my 91 t/a
Is getting a heart thanks plant
With a turbo going to be pulling
The current tpi 350 out and putting
In my fresh 6.0 lq4 with 317 heads
And on top of all that I just traded a
97 lt1 for a turbo for the lq it's going
Carbed with a msd box fourth gen rear
4.11 gears center console and seats
Car: 1984 T/A
Engine: LQ4
undercoat
cut out rust
fix my sagging door
redo suspension and steering
cut out rust
fix my sagging door
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
My winter project is my 91 t/a Is getting a heart thanks plant With a turbo going to be pulling The current tpi 350 out and putting In my fresh 6.0 lq4 with 317 heads And on top of all that I just traded a 97 lt1 for a turbo for the lq it's going Carbed with a msd box fourth gen rear 4.11 gears center console and seats
Engine: Cammed 6.0L LSX
Not a whole lot of interesting stuff for me this year.
BlueZee
2009 G8 GT
2013 Sierra
BlueZee
- Hybrid hawks double hump cross member with the T/A mount from the existing Spohn piece
- Swapping in an aluminum driveshaft with an upgraded 1350 u joint for my 8.8"
- Custom made late 4th gen Camaro leather seats (medium grey with ebony black perforated inner sections w/ black embroidered Z28 logos on headreasts
2009 G8 GT
- 6000k HID low beams
- Solo axle back exhaust (already done)
2013 Sierra
- GM chrome nerf bars
- Some sort of stainless steel catback system, haven't picked out one in particular yet
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
LS1/T56 swap
LS1 brake swap
Re-repair cracked frame rail behind steering gearbox while motor is out.
Hopefully it will be done by Thirdgenfest (Memorial Day Weekend) but thats pretty optimistic goal.
LS1 brake swap
Car: 1992 Camaro Z28
Every bushing, every energy absorbing component, every single suspension piece on my Camaro is getting replaced. A few items are being added i.e. subframe connectors and steering brace. Fully rebuilt steering linkage. Everything. Cannot take this squeaky rattle trap of a car any longer. That's all I have planned for the winter.
Car: 1991 Trans am
No I work in the service industry service in pan handle and I'll have most part of 3 months with no work
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
- swap to LS3 heads and intake
- TPS cam swap
- Port the heads
- NOS set up
- SOme other odds and ends
Piece together a turbo set up in the spare time along the way
- TPS cam swap
- Port the heads
- NOS set up
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Finish the LS1 swap in my 1969 firebird. The IROC's winter plans are it will probably just sit on dollies with the cover on it. I would like to replace the TPI gaskets but that probably wont happen. I think I have put 100 miles on the car this year... sad.
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Pull motor stud the block multi layered head gasket. Port the 113 heads and port the tpi base. Get some forged +12cc 355 pistons and maybe stroke it. All for a 200 shot off the juice. Msd box
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
To get my 91 either wetsanded and buffed out or repainted
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Car: 1982 Pontiac Trans-AM
Engine: 283
Transmission: Saginaw 4 Speed
Not have a rod knock, hit high RPM's without worrying too much about my bottom end giving out. Plus, it's a good .030 over shortblock. Saving some cash, I guess. It's still gonna put out more power than that 350 that's coming out.
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
Haul my car down to SC for a visit with Bruce to finish off my motor work and a new tune. Shooting for about or over 450rwhp when it's done.
Then, depending on how much money is left maybe paint and body work. I'd really like to get my car done and ready for F-Body Beach Bash at Myrtle Beach this year.
Then, depending on how much money is left maybe paint and body work. I'd really like to get my car done and ready for F-Body Beach Bash at Myrtle Beach this year. Joined: Sep 2005
It was my Christmas present from my wife/myself.
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
My winter project is to keep my Firebird on the road and away from other cars!
Ohio winter problems lol
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Not to much, paxton super charger, aftermarket shifter and steering wheel, paint, new
canvas top.
canvas top.
Engine: 283
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Just rebuilt my 355... It's now a 360 w/ 87 Corvette L98 Aluminum heads. Scat forged rods, Speed Pro forged flat tops, and a Comp Cams 268H.
The early snow in MA is killing me! My car is covered... I need to get the car towed to my new shop space, but it is completely buried :/
Mock up picture... Yes it's very red. Should look okay with the silver serp setup up front.
Engine: 305 TBI
LT1Formula
Oct 8, 2015 08:34 PM
