November 2014 COTM **WINNER**
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Re: November 2014 COTM **WINNER**
What the hell is that jack doing to the frame on the driver's side? fourth pic down. or is than an optical illusion?
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Optical illusion...the jack is on the tab where the subframe connector welds to the frame. I like to jack it up there when possible, its exra beefy there.
Have a 1991 Camaro Z-28 1LE. Can't figure out why it surges at idle. Replace just about everything on the car ECM, pickup coil, cap and rotor, injectors, IAC, vacuum canister, purge valve, EGR valve, 02 sensor and computer. I had it checked out today at a fuel injections specialist and every looked good. Every injectors was reading between 16.8 to 17.1 ohms. They did a smoked test and no vacuum leaks. Can you please with any ideas. Thanks!
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Linson
Oct 1, 2015 09:50 PM
the_hamturdler
Sep 30, 2015 12:50 PM
Linson
Sep 21, 2015 01:08 PM
david068513
Sep 18, 2015 10:36 AM
