Flex DA Polisher - Better than sex!!
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Decided to try out my new toy on one of my toys before I put her away for winter. The BEST money I've spent on a tool in quite a while.
Car: 1991 Firebird
Engine: 3.1L V6
Re: Flex DA Polisher - Better than sex!!
Awesome results!!!!!! Better than sex???? You must not be having sex, that or horrible sex. Time for a new lover.
What chemicals did you use?
Axle/Gears: 10 Bolt 2.73 Open
Those are some pretty sweet results. Would also like to know what products you are using with this tool.
Car: 89 Formula
Engine: Nada - v4.0
Not bad results for a 20+/- year old GM peeler program repaint.
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Looks great.
I really like the M1/205. The DA buffers are awesome, especially on black. Can't beat it.
Generally, I use a rotary buffer for paint correction and a DA for swirl/hollogram removal, polishes and waxes.
It's amazing what good products/pads will do with the correct buffer speed. Car looks fantastic, let's see some more of it!
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I have the flex as well, it works wonders. Only electric power tool I have that doesn't ever feel like it's pushing the limits of its motor.
Car: 91 Z28 Former KS. State Patrol Car
Engine: 383
Axle/Gears: Currie 9" 389 ratio
Is there another brand of polisher that works good but not so expensive as the Flex? Just curious as I wouldn't use it enough to justify 400.00 .
Just curious
Brian
Just curious
Brian
Car: 92 Purple Beast and 92 305
Engine: 406
Transmission: 700R4 corvette servo 2800 stall
Axle/Gears: 3.73 12 bolt Strange posi
While I have not used Flex to compare, I have been using the DA Polisher from Harbor Freight as polisher, buffer, and both wet and dry sander.
They also have 6" buffing pads for $5 each .
http://www.harborfreight.com/6-in-57...her-69924.html
Engine: 383
Thanks for the info. I have used a standard buffer several times but from what I have read the DA buffers work fantastic for the final stage. I am going to invest in one now its just deciding which one.
I have a 91 Z28 it is blue. It needs a good buffing again. Sometime when my wife helps me out I will get some pic's posted of it on here. I am not to good at computers so I need her help. lol....
Brian
Brian
bigjay89gta
Oct 15, 2015 08:04 AM
