Do I have clearcoat???
Old Dec 19, 2001 | 05:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I don't think I do, because I have waxed my car before and gotten some red residue on the cloth, which is according to the zaino website meaning I don't have clearcoat. Does this sound right. What is the advantage of having a clearcoat, just an extra layer of protection for the paint.
Old Dec 19, 2001 | 08:35 PM
Blue502's Avatar
If you have your original paint job, then you have clearcoat, however it may be worn all the way through in some or most areas. The original clearcoat wasn't very thick, and if you have been lucky enough to escape the almost inevitable clearcoat peeling, years of washing and polishing are likely to have removed most of it anyway.
If the car has been repainted, then it is likely that an enamel without a clearcoat, or a one stage enamel with clearcoat in the paint was used. These paints usually are less expensive and have a shorter lifespan.
The advantage of clearcoat is higher gloss for a longer period of time, and if done right, a deeper finish. Also, on a basecoat/clearcoat type finish, the basecoat is flat with no gloss to it whatsoever. It is also easier to blend in repairs, especially on metallic paintjobs. And finally if you put on enough coats of clear, you have the ability to do a real agressive colorsanding job, which gives you a super smooth and glossy finish.
Old Dec 19, 2001 | 08:50 PM
Car: 99 Formula
Axle/Gears: 342
It's not the original paint and I doubt it was expensive. The paint is chipping around the top of the doors. And in a spot they painted over a little bit of rust.
Old Dec 19, 2001 | 08:51 PM
Car: 99 Formula
Axle/Gears: 342
The reason I ask is because I want to order some Zaino, and I'm not sure which type to get for clearcoat or non clearcoat.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Catcher55
Aug 15, 2015 07:08 PM
Troy 85Z
Mar 16, 2001 08:51 AM
Mike-88CamaroTBI
Jan 27, 2001 04:30 AM
