Color match help
Old Jan 2, 2017 | 01:07 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
Transmission: 5-Speed
Color match help
I have a 85 iroc and I'm cleaning up some odds and ends. I'm wanting to repaint the air filter cover and fog light housing, can anyone tell me what kind of paint I should use (gloss, semi, flat) I'm aiming for original stock look, any input would be greatly appreciated
Old Jan 2, 2017 | 01:14 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Color match help
I know some are going to say flat & some semi but most likely it's TRIM BLACK which is just between both semi & flat. It's also what is used on the headlight buckets
Old Jan 2, 2017 | 01:16 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
would this also be the case for the rim lugnuts ( OCD will ruin me haha) and what brand would you recommend?
Old Jan 2, 2017 | 01:32 PM
rarebmx's Avatar
I'm not sure that I would spray a lug nut cover. I think with those I'd try a plastic polish on each one of use some sort of buffing wheel.
I'd use Dupli color trim black. Can GET At Most auto PART store. This is what it looks like.
https://m.summitracing.com/parts/shw...FUlNfgod62EBuA
Old Jan 2, 2017 | 02:35 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
would this be the same?
Old Jan 2, 2017 | 02:37 PM
rarebmx's Avatar
Looks right
Old Jan 2, 2017 | 02:43 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
Looks right
do you think it's safe or should I get something for high heat like this?
Old Jan 2, 2017 | 02:45 PM
rarebmx's Avatar
The air cleaner you could do in that but shouldn't require high heat
Old Jan 2, 2017 | 03:41 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
thank you for all your help! if your interested I can post before and after pictures as I go
Old Jan 2, 2017 | 03:53 PM
rarebmx's Avatar
You're welcome. Post for others
Old Jan 2, 2017 | 07:57 PM
Drew's Avatar
The lug nuts in 85 were steel capped. Plastic polish wouldn't do much except remove the paint. Any household rattle can would work for lug nuts. I want to say I used semi-gloss Krylon most recently, but Rustoleum, or Duplicolor, or anything really is going to work about the same. After a few on/off cycles they'll undoubtedly need to be repainted again.
Old Jan 2, 2017 | 08:22 PM
rarebmx's Avatar
Drew, once again is correct. The plastic capped lugs didn't arrive until 88. Drew will possibly help you from now on with your car.
Old Jan 2, 2017 | 08:26 PM
rarebmx's Avatar
These are the earlier metal capped caps & yes they won't polish but need painted.
On the air cleaner: paint it, then stick it in the over to bake the paint a little bit.
Old Jan 2, 2017 | 09:17 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
I ended up getting both paints above, the trim paint is definitely the shade I needed to get that stock look. I tried the engine paint on the filter cover first and it left this kinda sparkly finish tomorrow I will be sanding and hitting it with the trim paint. thanks again for the advice
