Factory Stickers
Car: 1987 Iroc-Z Camaro
Transmission: 5-Speed
Axle/Gears: 9 Bolt Borg Warner 3.45 Gears
Factory Stickers
Hey everyone, I'm wondering if anyone knows where I could find the original stickers that go on top of the radiator support? I need the black one with the belt diagram on it. Thank you for any help!
Andrew
Andrew
Re: Factory Stickers
What year/engine?
Google the 3 digit letter code. You will find the diagrams.
I've even seen some on eb**.
If you can find the diagram you're looking for, you can probably have it made into a sticker.
1987 305TPI LB9. What do you mean by the three digit letter code?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
'87 TPI's don't have belt routing stickers on the radiator support (mine doesn't). Probably because the '87 engines have a v-belt setup.
The only sticker that's on the radiator support is a yellow/black fan blade warning sticker.
The only other stickers are attached to the underside of the hood; emissions and vacuum hose routing. Both have the identical three letter code.
FWIW, this is the letter code in question ("ZDK" from my '87):
Mine is an XJW. 84 TA 305 "H".
And if I google "XJW emissions" I get this:
Thanks for the refresher, I completely forgot about that. I do have all the stickers then indeed. Thanks.
Thanks for the reference, yes i do have all the correct stickers.
