Few new pics of my 87 Z28
Old Oct 4, 2018 | 08:55 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Nice weather is slowly dying away, almost ready to tuck her away.
Winter plans consist of pulling the turbo setup and rad, repainting the engine bay and installing a billet s475 T4 turbo and 210lb injectors
Old Oct 4, 2018 | 12:25 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Re: Few new pics of my 87 Z28
Such a gorgeous ride! Love it!
Old Oct 4, 2018 | 12:50 PM
Ryan Fitz's Avatar
Car: 1988 Camaro
Engine: 5.3
Transmission: T56 Magnum F
Axle/Gears: 10 bolt Eaton trutrac 3.73
I follow your instagram. Solid photos and nicely built camaro.
Old Oct 4, 2018 | 02:00 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I really like this car!
Old Oct 4, 2018 | 07:58 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Awesome
Old Oct 4, 2018 | 08:30 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
freakin awesome car !
Old Oct 5, 2018 | 07:43 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Looks awesome.
I know you have probably posted this, but could you give the specs on the wheel / tire combo?
XXR526 right?
Size? Offset mm? And what spacers you used? Hubcentric ? and thickness
Thanks.
Oh yeah, Tire size.
Old Oct 5, 2018 | 08:52 AM
Jay_rich's Avatar
Car: 1987 Z28
18x10.5 +20mm BS Rear (i have a 1/8 spacer just to help clear the bump stops when the car is in the air.
18x9 +35mm BS Front (I run 1.25" non hubcentric adapters due to the corvette brakes) (stock car would require around 1.5" adapters)
Tires are Nitto Invo 295/35R18 and 275/35R18
I do have a slight rub at full lock. Only really an issue when im backing into a tight spot.
Originally Posted by bluegrassz
Looks awesome.
XXR526 right?
Thanks.
Oh yeah, Tire size.
Old Oct 5, 2018 | 11:59 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Thanks for the info.
Is the rear bolt pattern still 120.65 x 5 or did you have your axles redrilled?
I just worry about the difference between the 120.65 and the 120 bolt pattern.
Old Oct 5, 2018 | 01:50 PM
Jay_rich's Avatar
Car: 1987 Z28
Sorry, yes I redrilled. I originally had a Moser 9" with a 4th gen width, so while it was in getting narrowed to 3rd gen spec i had them add a 5x120 pattern in the axles
Old Oct 5, 2018 | 02:06 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Smart move. I know it is not much of a difference, but it is still a risk just bolting on.
I may pickup some 18x9 and run adapters on all for corners.
MeenZ28
Members Camaros
May 6, 2015 08:35 PM
camaroguy21
Aug 8, 2006 10:44 PM
Camaroguy18
Aug 2, 2006 08:18 PM
ghettocruiser
Mar 5, 2004 12:30 PM
Roshambo
Pacific Northwest Region
Sep 8, 2001 04:07 PM
