View Poll Results: Vote for March 2021 COTM!!! "Got Boost???"
customblackbird
20.00%
Bob88GTA
17.50%
indebt
20.00%
Charged355
27.50%
Thomas Aquinas
5.00%
pwdbychevy
10.00%
Voters: 40. You may not vote on this poll
March 2021 COTM "Got Boost???" **Voting Thread**
Old Feb 20, 2021 | 06:45 AM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
We have 6 great Boosted from mild to wild third gens for the March 2021 COTM "Got Boost???" contest... Nominee's please post up some great information to help the voters decide the winner! We will give nominee's a day to post up some more pics of their boosted rides and get some additional information to help with voting and then I will start the voting thread Sunday (2/21) afternoon
customblackbird | 1987 Formula
Bob88GTA | 1989 Turbo Trans Am Pace Car
indebt | 1986 IROC
Charged355 | 1987 IROC
Thomas Aquinas | 1986 IROC
pwdbychevy | 1991 Z28
Old Feb 20, 2021 | 07:51 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: March 2021 COTM "Got Boost???" **Voting Thread**
This car started out as a red 1991 Z28 with 305TPI and 700r4 automatic when I first bought it.
Engine info as follows:
Dart SHP 400 block punched out to 406ci
Eagle Forged crank
Scat H-beam rods
ICON Forged Dished pistons (9:1 CR) with plasma rings
CompCams 280XFI camshaft
CompCams1.6 ratio roller rockers with Assault girdle
AFR 195cc Eliminator heads 65cc
CVR electric water pump
ATI Super Damper
7qt oil pan
Edelbrock TPI intake ported and polished
Accel Superram plenum ported and polished and siamesed runner ports
BBK 58mm throttle body
SLP driver side header and modified passenger side turbo header with On3 88mm turbo(soon upgrading to Precision)
Tial 44mm wastegate
HKS SSQV IV Blow off valve
Godspeed 4" Intercooler with custom 3" aluminum piping
VMS Racing Oil catch can with -10an hoses and fittings
Snow Performance methanol injection
Transmission and Drivetrain
T56 out of a 1997 SS and Spec3 clutch Hurst shifter and line lock
Modified UMI trans crossmember to work with the T56
Spohn Chromemoly driveshaft
Quick Performance Ford 9" rear end with Aluminum thru bolt 3rd member and 3.50 gears
Suspension, Chassis and Brakes
PA Racing K-member and control arms
Front PA Racing coilover kit
Front LS brakes conversion
Rear QA1 coilovers
Rear LS brake conversion
Adjustable UMI torque arm and LCA
Adjustable UMI panhard bar
Founders Performance upper trackbar to clear custom dual 2.5" exhaust
JEGS 6pt rollcage
Chris Alston subframe connectors
Steinjager Performance rear swaybar
Hotchkis front upper strut bar
Fueling, Ignition and ECM
Jacobs Ultra Coil with MSD 6471 box(pictured is Jacobs Energy Pak box)
Siemens Deka 80lb injectors
Aeromotive AFPR
Dual in-tank Walbro GSS342 pumps(secondary pump boost activated via Hobbs switch)
Accel 8.8mm race wires
Autolite 3923 plugs gapped at .028"
-8an PTFE fuel lines
Fuel rail modified to accept 8an fittings
Tuning done via EBL P4 ECM (with tons of help from @Street Lethal thank you!)
Innovate PSB-1 WB
3 wire heated NB o2 for closed loop tuning
Complete Autometer Cobalt Digital dash(speedo, tach, oil pressure, coolant temp, volts)
Wheel and Tires and Exhaust
XXR 531 redrilled to fit 18x9.5 front 265/40 Michelin Pilot Sport and rear 18x11 305/35 Nitto 555R DR
Custom dual 2.5" exhaust with 3.5" electric cutout
Stainless 3.5" turbo downpipe
Wrapped in Vivvid Vinyl Black Aluminum
Duraflex SS hood modified with heat ports
Spaghetti Engineering rear LED sequential taillights
Bullitt Mustang gas door
Currently running 12psi of boost. I have yet to take this setup to the track or dyno pending a final tune. Huge thanks to Street Lethal for helping me nail it down!
The first test drive
Old Feb 20, 2021 | 08:09 AM
indebt's Avatar
Car started out as 305TPI/700r4 combo. Drove around for about 2 years before I started the swap in 2015. For various reasons, some of my own sabotaging, the build took longer than expected. I also went through great pains to keep the engine bay as clean as I could and hide stuff, thus resulting in more time thinking and less doing. Also at the time, I wanted it to be the lightest yet stock appearance. Car weighs about 2855 without driver.
Engine/Transmission
2002 sbe Iron 6.0
Brute Speed blower cam
Ebay headstuds
BTR trunion kit
Melling HV oil pump
LS2 chain
LS6 intake
Motion Raceworks valve covers with coil relocation
Stock 317 heads Comp springs pushrods
Fritts performance rmvb th400 with JW bell and transbrake
Cheetah shifter
ProTorque Convertor
Procharger kit
D1SC head unit
Custom 3.5" aluminum powdercoated Intercooler piping
Powdercoated head unit and alternator brackets
Big Red valve
Procharger 1300hp Intercooler
Fuel
-8AN Fragola PTFE braided fuel lines
4th gen Camaro plastic tank
Dual Walbro 450 pumps with one on Hobbs switch
Flex Fuel sensor
Fuel Injector Clinic 1000cc injectors
Racetronix fuel rails
2" Stainless Works headers
As yet finished 3 " or 4" oval piping
Undetermined mufflers
Ignition/Electronics
Holley Terminator X
Holley 6.86" Pro Dash
Stock truck coils with ICT coil relocation brackets
Jolt systems EV1 inj harness to better hide wires
Custom Billet Buttons for Main Power, Start and Lights
Motion Raceworks steering column mount
Motion Raceworks Grant Strange quick release wheel
Motion Raceworks Billet turn signal switch
Motion Raceworks ECU roll cage mount
10pt Moly cage painted cast iron
Kirkey 16" seats with Kirkey 55 series seat covers
ACC carpet without under padding
Rear end/brakes
Moser 9" 35 spline Moser Axles
Spool
Strange ProHD aluminum center section
Strange 11" disc brakes front and rear
Suspension/chassis/steering
BMR tubular kmember
BMR tubular A-arms
Lakewood 90/10 front shocks
Intrax 2" lowering springs
PA Racing manual rack
Moly custom made subframe connectors
Chris Alston Pro Torque arm and torque arm mount to 9"
BMR lower control arms
BMR Panhard bracket
Strange single adjustable shocks
VFN flat pin on hood with Trackspec Motorsports vents
Motion Raceworks dzus rails
Optic Armor rear tinted window
Glasstek fiberglass decklid
Wheels
RC Components 17x4.5" chrome Fusions
15x10 on 6.5" single beadlock chrome Fusions
M/T 26" SSR front tires
M/T 275/60 Pro Bracket Radials
Car hasnt been final tuned yet so no real numbers. I'll also add some more pictures as I can. In the video, I had taken off the IC piping as I was rerouting a few things.
Old Feb 20, 2021 | 08:56 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Thanks for the nomination!
Car was originally a 87 formula 350 TPI car that I picked up for $500 not running. Got it running and drove it for a few years and then pulled the 350 TPI for a built 383 HSR and a new built 700r4, thousands of dollars invested and 3 months after completing the swap (still tuning it) the car was stolen and gutted. I got the car back a week later, some mourning for a few weeks and decided to make the engine so big and hard to get out that they would have to cut the car apart making it not worth the time! I stuffed in a 521 cuin BBF custom fabbed everything and it was fun for a few years to say the least. Things got crazy with gas prices and I wanted to be able to enjoy the car more (and starting a family) so I decided to pull the 521 and swap in a 5.3 LS with a torque storm supercharger which was fantastic as I was still able to knock down 20mpg in the car cruising and had the boost to make the same power of the BBF. A few years passed and I wanted to be able to get more boost (I was maxing out the torque storm with there smallest pulley of 3" and about 10-12psi boost) so I decided to pull the supercharger and go with a turbo setup. I run a modified CX racing kit now and the car is an absolute blast to drive. I drive it all the time (warm weather) back and forth from CT to NJ and have been really enjoying the car and the 20mpg I get on the highway. This will probably be the final setup for the car unless I decide to go bigger on the motor like a stroker etc.
Engine & Drivetrain & Exhaust
5.3 LS with 150k+ miles shortblock is all original and didnt even gap the rings
Custom blower cam 218/228 .561/.561 114.5+5.5
Stock 862 style heads, mildly home ported, LS1 MLS head gaskets and ARP head bolts
Morel 5315 roller lifters, Moly 5/16" pushrods
Smith brothers bronze bushing stock rockers
90mm NNBS/trailblazer intake, 90mm WARR TB, home made throttle & kickdown bracket
72lb FIC bosch LS2 style lifters in billet fuel rails
Flowkooler HV water pump, GM HV oil pump, Fbody Oil pan, Powermaster 160amp Alternator, stock PS pump
Solid motor mounts, poly trans mount custom home made crossmember
Walbro 450lph pump in the stock tank, full upgraded 10gauge harness
Fitech ultimate LS EFI, 3Bar GM MAP sensor, stock truck coils, TR6 spark plugs, custom made under block spark plug wires
CX racing Modified single turbo kit, home sprayed creacote cermaic coating, customer crossover
VS racing billet 78/75 gen 1 turbo, 60mm HKS wastegate
3" custom mandrell SS downpipe, 3" electric cutout
4" Hawks sinister catback with vibrant SS street perf core straight through muffler
Truboost Electronic Boost controller allows spring pressure to whatever I want on the fly. I usually run 10-13psi on the street. Spring is 8psi and I have been as high as 15-16psi.
Snow performance water meth kit, AEM progressive water/meth controller, AEM nozzles running wiper fluid for detonation control, octane bump and additional inter-cooling. Black painted wiper fluid tank is my reservoir for the pump
3" FMIC with a 50mm Tial knockoff BOV
200r4 Built with CK performance parts rated for 800hp/800tq+, billet internals and hard parts
2400 stall billet 1000hp 10" converter
3" Denny's nitrous ready steel driveshaft (the one you can't break or they replace it for free) 1350 u joints
Jegster Drive shaft safety loop
ford 8.8 from a crown vic, 3.55 gears, built Tracloc Posi with mustang SVO carbon fiber clutch packs, ARP cap studs, Moser support girdle. Custom swapped by me before they had bracket kits premade.
Wheels, Tires & Brakes
C6 Z06 18x9.5 replicas
Front tires are Sumimoto HTRZ IIs 275/40r18
Rear tires are Mickey Thompson SS drag radials 275/45r18
Rear brakes are stock ford single disk drilled/slotted, ceramic pads
Front brakes are BAER black lable 13" drilled/slotted rotors, dual piston corvette calipers with HAWK ceramic pads, billet hubs and modified stock spindles
Suspension
Custom made Shortly tunnel mount TQ arm
Founders rear LCAs and PHB
Rear shocks are Viking double adjustable on home made Weight jacks running 175 rear circle track springs
Racecraft Moly Kmember
UMI tubular front control arms
Home made weight jacks 800lb circle track springs
Koni Yellow Front struts
Hotpart caster camber plates
Home made DOM strut tower brace with rod ends
TDS wonder Bar
Poly bushings everywhere on WS6 sway bars front and back
Home made thru floor sub frame connectors
Custom made hydroboost
Hurst Line lock, all new SS and copper nickle brake lines, SSBC rear proportioning valve
AFCO racing 13x19 dual row aluminum radiator no integrated trans cooler
Derale dual SPAL fans with shroud
Flexalite variable speed fan controller
Ford F450 superduty trans cooler (massive & basically a small radiator) trans temps never exceed 140*F even beating on it in 100*F temps
Car interior
Speed Hut revolution series custom gauges, 4.5" GPS speedo and tach, Innovate WB02/boost gauge with fail safe, speed hut trans temp, glowshift dual digital IAT gauge (pre and post IC temps)
Full new interior, door panels, Newark Auto Carpet, 4th gen seat belts
5th gen camaro front seats (drive is full power)
4th gen rear seats
Factory 3rd gen camaro ABS headliner, home wrapped in new black headliner, sail panels are wrapped to match
Sony Carplay 7" screen radio, 4.5" Rockford fosgate dash speakers, Kicker 6x9s in the sail panels, 8" sub self powered tube in the trunk and a 6x9 self power JVC sub/speaker
Backup camera for radio and a front camera for parking
Rebuilt rear hatch motor, upgraded TDS motor/housing
Exterior
OEM formula power bulge hood, new hood insulation, modified scoop to be functional
TA GFX kit, bumpers etc to make it look like a TA
JW speaker 8900 series DOT LED 5x7 headlights in rebuilt popups with upgraded brass gear motors
Custom made fog brackets for DOT SAE approved LED fogs
Stock TA rear rear grid style lights, modified wiring and lights for LED with almost full rear red lighting with turn signals moved to outermost light
VLED's backup light on license plate
Rear backup camera hidden in plate opening
Body work and painting by me in a car tent! Primed/sealed 2k urethane, summit stage 1 medium charcoal metallic 2k Urethane, 3 coats of medium solid Urethane Clear coat
OEM Z28 high rise spoiler
Metro Seal full weatherstripping kit throughout
Power output - No dyno sheets but I have 1/4 mile on my speedo and I use my data-logs to track power via injector duty cycle
Im able to max out my 72lb injectors (98% duty cycle) on 93 pump at 15-16psi which puts me at 750hp
Normal 10-13psi puts me in the 80"s % which is in the 600 range.
Best speed hut gauge 1/4 mile is 11.9s @ 120mph but was having traction issues goosing it on the street in first and 2nd and I was letting out early bc that's FAST on a no lights non straight road in the dark lol oh and that was on 10-13psi.
I drive this car to work, to the food store, take my son to school in it. It has fantastic street manners and gets awesome gas mileage.It see's daily long range trips 180+ miles in 1 day going to visit family in NJ. This is by far the most fun I've had in the car and I love the process of getting here and changing things.
Video of the car pre the 4" catback which I just installed this past summer.
Video after the 4" sinister catback was installed, you can also see the trail lights in this one.
Old Feb 21, 2021 | 06:11 PM
Charged355's Avatar
Car: 87 custom IROC
Engine: blown 355
Axle/Gears: 3:73
Thanks for the nomination, will keep this short and sweet. Not all details about the car are public, signature is a old setup.
4xx forged sbc running on MS3
Billet 88mm
fully done up 4l80 with circle d triple disk w trans brake
9” with a locker
Greg weld wheels with MT tires all around
Wilwoods
full tubular suspension front and back
sumped 4th gen tank with Aeromotive 3.5gpm brushless fuel pump feeding through a -10 on pump gas and meth with two nozzles
custom interior, paint, cage, etc.
Old Feb 21, 2021 | 09:54 PM
Charged355's Avatar
Car: 87 custom IROC
Engine: blown 355
Axle/Gears: 3:73
Billet 88mm
9” with a locker
Wilwoods
Old Feb 22, 2021 | 08:24 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Wow, some really nice cars got nominated!
Sorry I'm late to posting up info.
1986 Iroc. Originally an LG4/ T5. (I'm the 2nd owner, bought it in 1999)
408 LS (iron block)
AFR heads (I think 235s?)
Ported FAST 102 (Mamo)
Comp cam ( Also Mamo)
D1SC procharger, bracket kit from Indiana muscle car
Holley dominator EFI system
RPM transmissions 6-speed Magnum
Monster twin disc clutch
Moser 9" rear
4th fuel tank
Lonnie's twin pump fuel system. PTFE lines
UMI K-member and control arms
Custom Trans crossmember
Custom 3" exhaust
Kooks mufflers (off the 4th gen system)
I'm currently reworking the supercharger piping, so things are taken apart, but here's a few older pics.
Old Feb 25, 2021 | 08:30 AM
ksr's Avatar
ksr
Engine: 5.7 liter V-8
Transmission: 4 speed auto
Pretty sure that Heaven looks a lot like this.
Another tough decision this month. Great work on these cars.
Old Feb 26, 2021 | 05:24 PM
alan91z28's Avatar
COTM Editor
we have a quite a close race going for this month's COTM... get your final votes in by Monday morning!
Old Mar 1, 2021 | 04:02 PM
alan91z28's Avatar
COTM Editor
We have a winner!!! Congratulations to Charged355 and his beautiful 1987 IROC!
March 2021 COTM "Got Boost???" **WINNER** - Third Generation F-Body Message Boards
alan91z28
Feb 1, 2021 04:38 AM
QwkTrip
Apr 24, 2020 08:47 PM
ray jr
Apr 18, 2020 02:58 PM
QwkTrip
Mar 23, 2020 04:42 PM
