how wide of tires?
how wide of tires?
my dads 95 mustang GT has 245/45/17's and i was wondering how wide of a rim would i need to run a 45? i have 7 inch wide now and im running 235/60/15 how wide of a rim do i need to run 45s?
i have 235/60/15s on it now but i dont wanna go any taller already tall enough....my tires are taller than my dads and they are 17'' rims but it just has alot less tires on it...comon guys how wide to run a 45?
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
i have 265 50 15s on my 15*7 inch rims. they are only 26.** inches tall....and they're wide as hell. These are only on the back.
BTW the first number (265) stands for mm measured from bead to bead. the second number (50 for example) is the percentage of the first number which tells how tall the sidewall is. And of course the third is what Diameter rim it goes on.
I'm sure you know this but I just wanted to be sure because you keep mentioning 45s instead of 245s.
Hey guy,
A 45 series tire on a 15" rim would be pretty skimpy. The 45 is the aspect ratio compared to the section width of the tire. For example....a 235/60R15 would be a section width of 235mm, which is about 9 1/4" and the 60 means 60 % of that which is about 5 1/2" so that'd give you a tire diameter of 20 1/2" with a 15" rim......now...your 275/45ZR17 has a section width of 10.8" and a sidewall that's 4.9" so in total it's slightly larger in diameter than your 235/60-15 tire at almost 21".....follow this? So you don't want a 45 series tire on a 15" rim unless you are putting it onto a Hyundai accent or something
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I am running 245/60R15's all the way around on stock firebird 15X7" wheels, and they fit fine. They look great too.
Car: '89 Firebird
Engine: 7.0L
Go to BFGoodrich or Yokohama and they have application charts for their tires. Each tire will have range of suggested rim width. Choose a rim that is near the middle to top of the range.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
If you run 255/45/17's in the front and 275/40/18's in the rear they will be the prefect size. This is what i'm going to get!
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
