any way to remove or hide orangepeel without wetsanding?
Old Jan 31, 2002 | 04:05 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
My car never had a single trace of orangepeel until a couple months ago. Since then, it has just gotten worse and worse. I waxed it today, thinking it might maybe hide it a little, but it seems to have just brought it out more. HELP!
Old Jan 31, 2002 | 11:20 PM
Sauron91's Avatar
What is orange peel? post a pic of it if possible
Old Feb 1, 2002 | 01:22 AM
Jza's Avatar
Jza
Think about what an orange peel's texture looks like, and picture that texture on your paint.
You might not have to wetsand, but some type of abrasive is probably in order.
Old Feb 1, 2002 | 01:28 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
There's a way, but it's called a new paint job.
That's the only way (wet sand) to get rid of orange peal. Unless you want to spend about 200hrs cutting the paint with a buffer?
AJ
Old Feb 3, 2002 | 11:56 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Depending on how much paint and or clearcoat is on the car will determine the method to remove the orange peel. If the paint is very thin or original you really can't do anything to remove it or you take a risk of burning through the paint. If you know there is enough paint on the car (at least 3 to 4 coats) then you can wet sand the paint using either 1000, 1200 or 1500 grit wet/dry paper depending on how high the orange peel is. Also you should use a 3"x5" stiff foam sanding pad so the color sanding will be even. If you started with 1000 grit sand the car over again using 1200 or 1500 grit without the foam pad using the palm of your hand so every area gets sanded. follow by buffing with a thick wool bonnet and buffing compound (I use a synthetic compound) and then switch to a foam buffing pad and 3Ms finishing compound (I forget what it's called). It's a lot of work and the main reason why One Day Paint shops don't do it.
Old Feb 4, 2002 | 06:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Orangepeel doesn't just "develop" over time. It's either there or it isn't. You've got some other problem, probably rust forming under the paint.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
