How to remove foglight supports on IROC?
Old Mar 4, 2002 | 06:24 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Can't find it in a search, but how do I get these bad boys off? I want to take them off and paint them up.
Cheers
Old Mar 4, 2002 | 06:55 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
have you actually gotten under the car yet to look? It's 1 bolt.
Old Mar 4, 2002 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you remove the fogs themselves, you'll see, between the fog brackets, the threads of a screw/bolt. As I recall, I was forced to crawl under the car to reach the bolt head. Removal for me was quite difficult, but after soaking and resoaking (WD-40) the bolt/screw as I worked it, it finally came free.
JamesC
Old Mar 4, 2002 | 07:36 AM
Z28DJP1987's Avatar
What are you gone to paint on the fog lights?? If its the black
trim, forget about it. By now its rusted out, just take them off they serve no useful purpose. I did this a few years back and they look better then with the trim pieces.
Old Mar 4, 2002 | 07:46 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Yeah it's just the surround I want to paint. I may just take them off then. So far I have done nothing in that area apart from replace the foglight bulb. All I saw was the fog light adjustment thread which I wound out 'till I could get to the back.
I haven't been under the car to look at that part, hence me asking the question. Too busy changing plugs and leads
Cheers
Old Mar 4, 2002 | 07:53 AM
Z28DJP1987's Avatar
If you are gone to remove the trim, the fog lights DO NOT have to
come out. If they are rusted, they will fall off the fog lights.
Old Mar 4, 2002 | 12:39 PM
Jim85IROC's Avatar
Here's a before & after on mine
Of course, I had to replace the trim rings. :sillylol:
BUT, the reason I posted is that the trim rings I purchased had a little bit of surface rust on them. I sanded and painted them. If yours have more than a little surface rust, you're SOL.
Old Mar 4, 2002 | 01:52 PM
Z28DJP1987's Avatar
Save your time and money and just don't replace them and your not SOL.
Frozer!!!
Jan 19, 2024 04:55 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
