Wiper Arm Question
Old Apr 3, 2002 | 05:53 PM
VampireHunterC's Avatar
Wiper Arm Question
My passenger side wiper arm will not go all the way back down. I can pull it down past the little tab that it rests on, and it will be fine for a little while, but after I run the wipers a couple of times, it will only go down to about 1/2inch above the little tab. Any ideas on why it does this and how to fix it? Not a major issue, but just annoying.
Old Apr 3, 2002 | 10:59 PM
Kandied91z's Avatar
sounds like it isn't aligned right; remove it and run the wipers with them off, then turn the motor off........place your wiper in the desired "off" location and everything should be fine; if it keeps doing you might have either broken a tooth on the gear or something worse....
good luck.
Frozer!!!
Jan 19, 2024 04:55 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
slade5612
Aug 11, 2015 07:19 PM
