sprayed aircraft stuff on iroc rims and....
Old Apr 7, 2002 | 10:22 PM
Camaro-Bum's Avatar
been reading info on how to restore iroc rims and got REAL lucky. got some spray on aircraft stripper at walmart and since my wheels looked so bad decided to spray some in and inconspiicuous spot and drove home. pulled up and got out and DAMN!!!!!!! the spot was was sparkling. tried more on one half of an entire wheel and S.O.B. !!! totally perfect. got a theory on that stuff{aircraft stripper} i think that since i'd been driving all afternoon the wheels were warm and spraying the klean strip on at that particular time helped. it seems that the old clear just bubbles right off if the strip is applied when wheels are warm. just alittle sumthin sumthin for you fellas to consider.
Old Apr 7, 2002 | 10:28 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Pics...............my kingdom to see some pics!
Old Apr 7, 2002 | 10:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just remember by removing the clearcoat you're wheels won't have that protective barrier, so keep them cleaned. I still have to do the front ones.
Attached Thumbnails sprayed aircraft stuff on iroc rims and....-irocwheelpolishsidesmall2.jpg
Old Apr 7, 2002 | 11:10 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Unless you feel like polishing your rims EVERY week, I suggest putting clear coat on them. I didnt put clearcoat on my 2 front GTA rims, and now theyre trashed. I have to resand them totally and start from scratch.
Old Apr 7, 2002 | 11:21 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I don't know about your theory, but that stuff works like magic. I haven't driven my car for a week. I put some of that stuff on my wheels, after taking it off the car first. It worked great.
I painted my calipers too. I used it on the back caliper prior to painting and the caliper turned out super clean and black, the color of the metal, not the color of the dirt and grime. The calipers are now "Chevrolet Orange-Red" from WalMart..........Sweet!!!
Pics soon.(I have to get the film developed.)
Later,
Jesse
Old Apr 8, 2002 | 07:38 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I wouldn't put that stuff on your wheels then go drive around. It'll sling all over the side of the car.
Old Apr 8, 2002 | 08:13 AM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
a buddy of mine was repainting his door and used it on that.. this was paint, upon paint, upon paint.. about 3 or 4 layers of paint on top of one another and it bubbled it rigt up. he wiped it off with a rag a few minutes later....
Old Apr 8, 2002 | 08:17 AM
Car: 99 Formula
Axle/Gears: 342
Exactly, ever had tire shine do that, at least that's paint friendly.
Old Apr 8, 2002 | 08:21 AM
oldblueZ's Avatar
Car: 85 Z28
FYI...not all tire shine is paint friendly...put it on, then wipe off any excess.
Old Apr 8, 2002 | 09:05 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Where do you get clear coat for your wheels at?? Thanks
Old Apr 8, 2002 | 11:28 AM
Car: 99 Formula
Axle/Gears: 342
Just buy the spray paint kind, has a clear lid.
Old Apr 8, 2002 | 11:33 AM
Black85TransAm's Avatar
Good stuff that aircraft stripper is...really strong too!!i used some on my pontiac rims and it worked pretty good(then Camrs89 sold mea set of CragarSS rims for 100$ hahahahahahah..)
Old Apr 8, 2002 | 11:54 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
My Dad told be a body shop story of some painters helper that was trying to strip the paint from a fender. He was probably using stronger stuff then air craft but it started dripping on the tire. I guess he didnt think it was to harmfull. Before you know it that damn tire bubbled up and EXPLODED. No joke, that guy wasnt to bright.
>BTW I did the same to my rims and it keeps them nice and clean. I used that Klean strip and man does that **** suck. I took me two cans to get it all off. A good tip is to spray if off with a high pressure water hose. Now I used a car wash and had to spend the extra money to spray it off the ground and over by the fence. (cheaper then a law suit if that gets on anyone elses car)
Old Apr 8, 2002 | 12:31 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, I would definately not get that stuff on the tires.
Old Apr 8, 2002 | 02:28 PM
89Formula305's Avatar
i own some of that aircraft stripper, I like the results..
Old Apr 8, 2002 | 02:36 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Where do you get the aircraft stripper stuff and what does it cost? Also, what kind of clear coat would you recomend putting on afterwards?
Old Apr 8, 2002 | 02:40 PM
oldblueZ's Avatar
Car: 85 Z28
WALMART!!! $3.97 + tax. It's in a big blue can.
The clear I got was from Walmart too, but I haven't sprayed it yet, so I don't know how good it is.
Later,
Jesse
Old Apr 8, 2002 | 03:07 PM
Car: 99 Formula
Axle/Gears: 342
They also sell the aircraft stripper in a spray can for like $5.
Old Apr 8, 2002 | 03:24 PM
Surprizingly, the stripper doesent hurt tires... not that I saw anyway.
Old Apr 16, 2002 | 11:08 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
ok I need help
so you sand off all your paint first..
than spray that stuff on??
WHAT ABOUT MOTHERS POLISH STUFF?
is that the same?
and than the clearcoaT?
Any advice for painting the GFX also?
Old Apr 16, 2002 | 11:09 PM
no need to sand... the stripper will do all the work for you. Uhh, I mean "paint" stripper...
Old Apr 18, 2002 | 06:04 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
so your wheels get all shiny like Marks without polishing or anything? just spray the stripper and clearcoat? sounds too easy for such good results.
Old Apr 18, 2002 | 06:18 PM
oldblueZ's Avatar
Car: 85 Z28
mark did polish his wheels. If you just spray on the stripper, they will definately be shiny, probably not as good as mark's. but if you polish them, they will look even better. your choice.
Later,
Jesse
Old Apr 18, 2002 | 08:16 PM
Car: 99 Formula
Axle/Gears: 342
Spraying that stuff on didn't make mine shiney. I had to sand and that's when it started getting better. If it were that easy I wouldn't have gone over the back ones 2x.
Old Apr 18, 2002 | 11:17 PM
oldblueZ's Avatar
Car: 85 Z28
mine were so bad that without anything else done to the wheels, you could tell they were much shinier.
I am working on the sanding and polishing, but that is taking longer than I projected. I also have the rally wheels, not IROCs, so I have to sand off a LOT of aluminum cast.
Later,
Jesse
Old Apr 18, 2002 | 11:44 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Don't you have to keep on putting polish on them when you are done to keep them looking good since you take off the stock clear, and isn't it the same with the plenum??
Old Apr 18, 2002 | 11:50 PM
oldblueZ's Avatar
Car: 85 Z28
from what I read, if you spray a clear coat over it, you don't need to polish it anymore. I haven't tried it yet because I have not been able to finish one wheel yet because of the lack of time school gives me. Mark might know for sure.
-Jesse
Old Apr 18, 2002 | 11:53 PM
Car: 99 Formula
Axle/Gears: 342
I've been reading, spraying clear on them defeats the purpose. Also it could turn yellow. And no you don't keep polishing them as that may dull and scratch the shine. Just keep using windex (ammonia free) and they'll be good to go. I'm going to try the carnuba wax thing for protection.
Old Apr 19, 2002 | 10:00 AM
Nope those EPA laws took car of that. Well I'm talking about the stuff they used in body shops 10 years ago. They made it Illegal because to many people were being stupid and touching the stuff. I herd if you let it sit on the sidewalk I would eat a small dent. NO its acid! The new stuff might not do anything except make a brown spot in your tire.
>3 bucks? I payed 6 for some clean strip and its weak. Took me 2 cans. For some reason I can find it here in Texas
Old Apr 19, 2002 | 02:02 PM
RaGe's Avatar
Car: 1990 Firebird Formula
As JimIroc85 said, be VERY VERY careful with that stuff...
I used it on my 88 Formula wheels, and yes it works well. so well that if you don't get it all off and some flys on the quarter panel, be ready to see primer or bare metal.
It eats what ever it touches, and will turn your tires different colors also.
Best practice is to take the wheels off the car, let it sit and scrape it off. If you must do it on the car use the brush on and do thin coats. masking your car wouldn't hurt either.
I also had them polished by someone with the tools to do so when they where done... results where not bad at all..
Old Apr 19, 2002 | 02:27 PM
Is it wrong to use this stuff at a car wash?
1992rs/ss
16
Jan 28, 2016 09:58 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
