Adhesive
Old Apr 15, 2002 | 12:21 PM
urbman's Avatar
Adhesive
My 1990 firebird has been modified
with a 91-92 style spoiler.
It is the large wrap around piece.
Unfortunately the top and bottom halfs are
separating.
I would like to glue them together
but am not sure what I can use for an adhesive.
Old Apr 15, 2002 | 04:03 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Epoxy
Old Apr 15, 2002 | 04:07 PM
urbman's Avatar
Hmmm....
Although I think this thing
is from a 91-92 car
it might be aftermarket.
Markings on the wing...
VT 2029
PT NO 10179101
MAT XENOY
PET/PBT
Here is a picture
of what I wish to glue
Any advice would be appreciated
Old Apr 15, 2002 | 04:22 PM
urbman's Avatar
>>>Epoxy
Hmmm....
I was hoping for a bit more :-)
Old Apr 15, 2002 | 08:13 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Well, Epoxy is a good answer... but more specifically...
If it is a Fiberglass wing then Epoxy is probably the best thing to use... Elmers makes a simple to mix 2 ton epoxy that squeezes out two equal amounts of hardener and resin and it can be found at k-mart, Sears, staples, office max and any hardware store...
If it is metal then you should use JB Weld... it's basically metal epoxy... that can be found at any respectable hardware store and probably anywhere I listed above.
Be ware if the wing is made of ABS Plastic... some epoxies may eat it... contact cement would be a safe bet for that case.
If it were wood (LOL) which it isn't and never would be... but if you had a wooden component your best bet would be elmers carpenters wood glue (light brown type)... it's at least equal in strenght to most epoxies...
Better response?
-CPC
Old Apr 15, 2002 | 09:26 PM
urbman's Avatar
The wing is made out of something called xenoy
There is a site ...
http://www.urethanesupply.com
that describes xenoy as a polycarbonate
blend.
They also have a string of seemingly well
written "newsletters" describing most of the
plastics I have ever heard of and quite a few I
have not...
Of course they plug the stuff they make.
I am going to give them a try....
I am just a bit cautious due to some painful
lessons from my motorcycle days ( 80's ) :-)
Its worth 20.00 bucks for me to find out...
Old Apr 16, 2002 | 09:40 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
On plastic parts I use Devcon Plastic Welder and Plastic Welder II epoxies. The difference is the cure time. PW allows 8 minutes to position the part and PW II allows up to 20. http://www.devcon.com/devconsearchresultframe.cfm
Lon
Old Apr 16, 2002 | 10:13 AM
urbman's Avatar
Thanks Chill, lonsal, KjRockz !
Old Apr 18, 2002 | 07:30 PM
urbman's Avatar
I ended up using a product available
at my local body shop called Duramix 4040.
It is somewhat hard to use as you must
use their injector setup that uses
a special mixing tube.
Once you start ejecting this stuff you must not
stop as it hardens in the tip in about 60seconds.
So far it seems to harden roughly like
a thick POR 15.
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
tcflint
Sep 14, 2015 04:55 AM
Omega
Aug 10, 2015 12:46 PM
89-28gp
Feb 8, 2003 06:50 AM
Tom Keliher
Aug 5, 2002 09:04 PM
