oil filter coolers?
Old Apr 15, 2002 | 04:09 PM
86BIRD-MY FIRST CAR's Avatar
oil filter coolers?
i saw this thing that looks like a circular piece of metal with padding and ridges that wraps around your oil filter with built in heat sinks like the ones in your computers, it claims to reduce oil temperature. any one see this thing or does it really work?
Old Apr 15, 2002 | 05:36 PM
Kaps's Avatar
i had one on my 84 Z28, temp did drop a lil bit, plus it was only like 10bucks, so it was worth it, EASY to install, lol. Id get it again
Old Apr 15, 2002 | 05:38 PM
Kaps's Avatar
But if your that worried about it, you might as well get a oil cooler like a radiator style, they work VERY well, plus if u have an auto they do have combination for oil and tranny
Old Apr 15, 2002 | 08:08 PM
2vmodular's Avatar
i have an external oil cooler on my interceptor. standard civilian oil filter holder that bolts to the engine block is replaced with one that has two hose fittings on it (inlet & return). hoses then run to oil cooler that is located near the radiator.
Old Apr 16, 2002 | 11:08 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My LT1 has oil cooler lines attached to it, I just need to find the radiator part. My motor came from a Caprice 9C1 Patrol Car.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
