different headlight motor question
Old Apr 15, 2002 | 06:41 PM
MrTat2's Avatar
ok, i need to replace the headlight motor in my 87 gta, but i have a different problem. the light doesnt go up when turning on the swith, so i tried to raise it manually. but it didnt go up maually either. i twisted and turned, and no avail. my question is now how do i get to the 4 screws to remove the headlight assembly? do i have to remove the front facia? i sure hope not....any help would be nice so i dont have to dive in blindly. it is the pass. side if it makes any difference.
thanks, Brad
Old Apr 15, 2002 | 07:08 PM
scauffiel's Avatar
Well your gear is probably stripped to the point where it's not "grabbing" - did you try to pull up on the headlight assembly while spinning the manual control? That's what I had to do to raise mine...
Steve
Old Apr 15, 2002 | 07:16 PM
MrTat2's Avatar
i tried thats. what was happening was the motor was makeing a grinding sound kinda....then i would try to "assist" the light up but to no avail. then i decided to take the motor apart while on the car....big mistake. i took things apart, but then i couldnt get them together again...oops. my luck i will have to take the farking facia off to get to the screws.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
