Ultralite Gauge pics inside
Old May 3, 2002 | 03:52 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Here is my completed dash with all my Autometer gauges. Thanks to Slush92RS for showing me it could be done. Let me know what you think, good or bad. No I am not changing the steering wheel as the car is going up for sale.
Old May 3, 2002 | 03:58 PM
johnsjj2's Avatar
Car: 1991 Z-28
Heres another:
Old May 3, 2002 | 04:12 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
That looks great. Any pic's of the complete car? and why ya selling
Old May 3, 2002 | 04:37 PM
johnsjj2's Avatar
Car: 1991 Z-28
The only other pics I have are of the engine bay. One good one is below. I am selling due to a baby on the way, and this now puts us over the space I have in the Grand Prix, and the Intrepid. I have to sell the Camaro, to make up all the negative equity in the Intrepid and get one of those rectangular, box looking vehicles. Some people call them mini vans. Oh no, I said it!!
Old May 3, 2002 | 06:44 PM
bjm323's Avatar
Car: '91 Camaro RS
johnsjj2
That is tough looking. I really like it. To bad you have to sell but, Congratulations. Check your Private Messages.
Old May 3, 2002 | 07:13 PM
johnsjj2's Avatar
Car: 1991 Z-28
Brad,
I'm at work, so after our meeting, I will respond to the PM.
Thanks,
Old May 4, 2002 | 03:27 AM
toosloz's Avatar
fuel sender a pain to hook up?...how was the install?....that pod...where you get that?
Old May 4, 2002 | 07:27 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
2-1/16" 2-5/8"
4314 4414 Fuel Level (0 Ohm Empty/ 90 Ohm Full)
For most GM vehicles from 1965 to present.
Old May 6, 2002 | 02:33 AM
toosloz's Avatar
how hard was the wiring?
Old May 6, 2002 | 09:04 AM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Guage size
Are the speedo & tach 5" ?.........
Thanks.
Old May 6, 2002 | 05:00 PM
johnsjj2's Avatar
Car: 1991 Z-28
Both the tach and speedo are the 5" models. The pod used for the 3 gauges under the vent, I made ar work. I used 2 1/4 tubing that was scrap water tubing, and cut it down. I then welded a 1" strip of flat stock across them as they were angled. I also took 3pcs. of 2 1/4" square sheet stock, and welded them to the back. The corners were ground smooth. The cups ended up being to short. I didn't allow for the light to stick out. So I used a die grinder and cut out a rectangle from top to bottom so the light would fit. After all this was done, I painted them black. The wiring wasn't to bad. A member on here e-mailed me a diagram of the wire-outs in the 2 blocks. That was probably the biggest help I had. I could not have done the wiring w/o it. I only added 1 wire and that was for the oil pressure sending unit. There is a maze of wires behind the dash now. I just made sure all connections were solid, and covered each one with heat shrink tubing. I wrapped all the wiring from the gauges on the right with elec. tape to keep them neat and organized. You can see it in the pic below. If you take your time, it will look good.
Old May 6, 2002 | 05:59 PM
5SIZ's Avatar
Car: 1987 IROC-Z
testing
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
ChevyZ71
Aug 13, 2015 07:30 AM
