ignition switch problems
Old May 7, 2002 | 12:05 AM
bottlefed89's Avatar
when i turn my key it only goes as far as the run position and if i sit and mess around with the key it will eventually move to the start position then it comes right back and everything seems fine, what would cause this? have heard too many different things just looking for someone who this may have happened to
thanks for any help.
Old May 7, 2002 | 02:19 PM
CD MaroMan 91's Avatar
is it like where the key won't move forward... mine does that... i cant' even turn it back 2 listen 2 the radio unless i turn the key to ON... i have to like push it in while turning back and then real quickly turn it forward 2 crank it up.... just another thing messin up on my car... haha
Old May 7, 2002 | 02:39 PM
86IROC350NY's Avatar
solution
Go to a locksmith...they may be able to fix it cheaper than a mechanic. If he refers you to a mechanic then you will pay 120 for parts and labor...the mechanic told me that it was cake.
This is what happened to me:
I was having problems, then one day i could not turn my car OFF...the key was stuck in the on position. So I neede to unplug the distributor to turn off the engine, then unhook the battery to turn off the fan....big PITA
--Dan
Old May 7, 2002 | 05:51 PM
MILT's Avatar
It sounds like something is binding either w/in the ignition cylinder or w/in the ignition switch itself. I would try fiddling with the ignition switch...its under the dash on the top of the steering column. Remove it, or back it away from the rod that goes up to the ignition cylider, then try moving the key through various positions (disconnect the battery b/f doing this). If everything seems okay, then put in a new ignition switch--easy, costs arond $45 I think. Otherwise if you're still having problems, then your ignition cylinder is probably messed up and needs to be replaced.
MILT
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
